2 exhaust questions....(93 and 96)
Old Apr 22, 2004 | 09:45 PM
st08x's Avatar
i unbolted my exhaust from my cat but is there any really secure way to hold it up? i took a c clamp and but it through the flang to the heat shield (i think) thing but i was just wondering if anyone else did it any other way.
my other question is for my buddy, he's got a 96 z28 and we were looking at his exhaust the other day and he only has one cat. he has the 2 pipes from his motor to a y-pipe and only one of them has a cat on it, not the other. is that possible? doesn't that make it have unequal back pressure? and were is a good place to put a cut out on a 96?
Old Apr 22, 2004 | 09:48 PM
Buttercup's Avatar
Why did you unbolt your exhaust????
If it's for temporary situations (such as the track) than get a cutout. If it were permanent (to make yourself and others deaf) than just remove it, it's dead weight
As for the '96, there are two cats. Hint: look up further towards the very end of the exhaust manifold
Old Apr 22, 2004 | 10:07 PM
st08x's Avatar
yup, that's were it is, why did they put it so much closer than the other one?
Old Apr 22, 2004 | 10:13 PM
Buttercup's Avatar
#1 is packaging. There's not much room to fit things in/under there
#2, the closer a cat is to the exhaust ports, the quicker it will reach "light off" temp and the less cold start emissions will be emitted.
Old Apr 22, 2004 | 10:15 PM
stereomandan's Avatar
It was the only place to make it fit well I think without loosing too much ground clearance. Also, having it that close to the engine heats it up quicker which gets it working sooner.
I just put MAC headers on and switched from the '96-'97 dual cat design to the '94-'95 single cat style. I like it better, but I'm still a little concerned because my single high flow cat still causes more backpressure than my dual stock converters. I'm thinking of replacing my single high flow cat with a Dynomax bullet muffler.
Dan
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
