2 Clylinder Misfire
Old Jun 21, 2011 | 08:37 PM
Lt1SnakeCharmer's Avatar
2 Clylinder Misfire
got a 96 camaro z28 lt1, 6 speed misfiring 2 cylinders cant figure out what it is new opti, new fuel filter, new cold air intake, new egr, new fuel pump, cant figure out whats goin on any suggestions? ive read so many forums on here and cant figure it out, o and new plugs and wires
Old Jun 21, 2011 | 08:54 PM
cnorton's Avatar
Re: 2 Clylinder Misfire
Is an electrical impulse reaching the injectors on each of those dead holes? If the impulse is reaching the injectors, are they delivering fuel on those holes?
Old Jun 21, 2011 | 08:55 PM
moparman's Avatar
Have you had it on an enhanced OBDII scan tool? That should tell you which cylinders are misfiring.
Old Jun 21, 2011 | 10:06 PM
cnorton's Avatar
True...as will a visual inspection of the spark plugs. Or, a heat gun could help identify which exhaust ports are colder than the others.
Old Jun 21, 2011 | 10:12 PM
i checked the obdII scanner and all that came up was the temperture sensor on the front of the water pump but i still gotta replace it so no worries there. i somehow think it jumped time on me. everything else is new only thing that aint new is ICM and coil but i dont think itd start at all if those were bad. the injectors r getting fuel because i get a backfire at 3000 rpms thats y i think its the timing. i got no power. its got a 393 full posi so i kno when its screwing up
i wanna thank u guys for any help u can offer i could use it ive been thru it all. i might just get a new computer then have it done for all the extras
Old Jun 21, 2011 | 11:28 PM
well from what im reading the code its throwing could be my issue.
http://www.obd-codes.com/p0118
Old Jun 22, 2011 | 12:59 PM
Well now I'm getting the random misfire code. P0300
Old Jun 22, 2011 | 02:15 PM
moparman's Avatar
You mentioned OBDII scanner. Is this an enhanced scan tool, or a code puller? The enhanced scan tool will show the individual cylinder misfire counts.
The P0300 can be a tricky one to track down. Lots of people have posted about that one, but no one comes back to say what it was. The times I've had it, it was always a plug wire.
Old Jun 22, 2011 | 03:06 PM
I used the enhanced one and said it was misfire p0305 so cylinder 5 is misfiring and we pulled injector plug 2 and 4 and made no difference so its a headache lol
Old Jul 6, 2011 | 08:34 PM
well my injectors r bad
Old Jul 7, 2011 | 05:27 AM
Guest47904's Avatar
Guest
How did you come to that conclusion??????
Let's back up. You have a code for #5. You pull the injector clips off 2 and 4 and it makes no difference in the way it runs. Is that correct?
If that is correct, you should have a misfire code for 2 and 4 also. Did you pull the clip off #5?
So now exactly how do you know it's the injectors causing any problem? Simply because when you pulled them off, nothing changed????????
You never said anything about a code but provided a link to 118. Do you still have any codes?
Old Jul 11, 2011 | 03:03 PM
the only code i get with a regular code puller is random misfire but with the better scanner i get it on #5. 2 and 4 work one minute and not the next so i ordered new injectors they r on their way. when i get them i will install em and clean my fuel rail just to make sure everything is workin right. if their is still a problem i will let it be known. after that ima sit down and think what else it could be. if the icm was bad it wouldnt start? how about the coil? we'll see how these injectors improve it or keep it the same then go from there.
Old Jul 11, 2011 | 03:49 PM
Guest47904's Avatar
Guest
Why are you buying injectors without further examination. Rarely is injectors the cause of misfires/dead cylinders.
Old Jul 11, 2011 | 04:07 PM
well thats what i think it is when i replaced the fuel pump last year i didnt put the sock on and not long after that it started sputtering and backfiring
Old Jul 11, 2011 | 07:54 PM
Regecide's Avatar
Get some brake cleaner and pull out each injector and inspect them. Clean them out. If your car has been sitting for a while you probably have some rust running through the line and clogging one of them, would definitely cause the misfire.
Just pull them out and look down the hole, if you cant see all the way down them, spray it and try again!
Might as well check them anyway, they're easy to get to and it takes 20 minutes, no sense in buying new ones if you can just clean them.
