2:73 too 3:73 or 2800+stal tq?
I have been reading that there is not much of a 1/4 mile ET increase with gears and i would be better off just getting a tourq converter.
SO if i can only get one what will give me the best ET increase in 1/4 mile and any reason you think i sould get either one
My best with shorties, CAI, MAF and 2.73's was 14.1@99, put in 3.73's and a cutout dropped to 13.5@105.
Its a HUGE difference when your going from a roll, from a stop, not as noticeable. Although, I've debated on going back to 2.73's and getting a good TC...not sure though.
But, get gears...you'll likey
Originally posted by BigEvil
I would definately recommend the gear swap. It's well worth it.
I think that no gain b.s. is just that... b.s.
The SOTP gain is amazing though!
Hot Rod Hawk(Mod in the MI section) was one of the guys that told me i wouldnt gain, he had swapped also.Guess what, he ws right. I went 14.1 @99 with 2:73's went 14.1@99mph with 3:73's
That being said, it felt faster with the gears, and when I put in a 2800 vig, i dropped 9/10ths
If I were you, id go with gears first, and get a converter asap
i went the opposite, i went with the tc, i dropped almost 6 tenths off with it and drag radials, went from a 14.49@97 to 13.91@98 with it because it took my 60' from a 2.3 to a 1.9, my next mod will be a set of gears, just deciding on 3.42 s or 3.73 s
If you do any racing "outside" the track, then get the gears. A 40mph roll w/ 2.73's suck.
mickeyiz28
Mar 26, 2003 12:53 AM
3.73s
I have both and have not gained much!?!?!?
