1st 2 times I take off the manifold, everythings turned out fine, now
Old Aug 11, 2006 | 07:47 PM
speed_demon24's Avatar
I just put on a ported LE intake manifold, and now I have the famous rear intake manifold leak. I put a ****load of RTV on, and the car actually sat 2 days before I started it up, I don't know wtf I did wronge. I guess its coming off for a 4th time now.
Old Aug 11, 2006 | 09:02 PM
Severous01's Avatar
Re: 1st 2 times I take off the manifold, everythings turned out fine, now
sorry dude...just be glad you didnt jack up something else. i know it's a PITA to take off and put back on, but once ti's right you'll be happy
Old Aug 11, 2006 | 09:20 PM
Green95Z28's Avatar
This may be a dumb question but did you be sure and scrape off ALL the old gasket material? Then make sure there was 0 oil anywhere around where the RTV is gonna be? How are you torquing the intake? If you have already done this stuff disregard this post
Old Aug 11, 2006 | 09:45 PM
I scraped it all off, I think i forgot to use brake cleaner on the surface material though. I torqued it down with the factory patern. I'm goign to cut off the headfs of bolts and use the studs to line it up this time.
Old Aug 11, 2006 | 11:31 PM
revtime's Avatar
Yeah, make sure you don't smear the rear bead when setting the intake down. I did that recently when I put the Nitrous manifold on. Had to pull it again the next weekend. After a few heat cycles retorque your bolts again.
liamcg97
Nov 25, 2019 05:55 PM
tds1213
Nov 27, 2014 12:55 PM
DrMilhouse
Oct 2, 2002 05:03 PM
Rino1313
Jul 19, 2002 04:31 PM
Rino1313
Jul 18, 2002 05:16 PM
