1997 Cluster pinout
Old Aug 2, 2005 | 03:02 PM
Shon Herron's Avatar
1997 Cluster pinout
Would my 97 be the same as this 95 pinout from Shoebox's site? (thanks btw)
http://shbox.com/1/95_z_cluster_pinout.jpg
Old Aug 2, 2005 | 03:05 PM
white/blackss's Avatar
Re: 1997 Cluster pinout
NO!! there not even close, the dash cluster from the 95to the 97are completely different. it took me for ever to rewire my 94 to use the 97 cluster in my car.
what is it that your trying to do? can you give us more info on the car and what your trying to do and i bet someone here can help you out
Old Aug 2, 2005 | 09:18 PM
Gotcha, they have totall different set ups....
I am wanting to get the RPM(tach) signal from the plug in. I know the wire is white but to me it looks like 2 white wires in the plug in.
I have tried to get the signal from the PCM area but for some reason it dont work. I have tried 2 different RPM Switches, I know I have power and ground, I just am not getting the signal for the RPM.
I could also get it from the coil area but not real sure which one to get into...
Any help would be greatly appreciated.
Old Aug 3, 2005 | 06:16 AM
If You Have A Multi Meter You Can Check The Voltage At The Coil Wires, Theres 4 Of Them. I Would Bet That It`s The White Wirs On The Coil Plug Aswell.
Put The Tester On The 12 Volt Scale And Start Up The Engine, Ground The Black Wire On The Multi Meter And Take The Red Wire On Your Multi Meter And Test The Wires At The Coil.
One Will Pulsate The Meter, Thats Your Tach Wire.
The Pulsatation Will Be Very Little So You Will Have To Look Closely To Catch It. This Is What I Have Always Done In The Past To Find The Coil Wire If I Coundn`t Pull A Diagram On It.
IndyZman
Oct 22, 2015 02:17 PM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
maverickmk
Sep 1, 2015 09:17 PM
