Timing set install question
Just want to be sure I have this right before is slap the rest together
1996 lt1 motor. heads/intake off. Just a simple H/C swap.
#1 piston all the way up
cam dowel pin @ 9
cam gear dot @ 12
crank gear dot @ 12
Is that correct for TDC #1?
cam dowel pin @ 9
cam gear dot @ 12
crank gear dot @ 12
Re: Timing set install question
Shoebox has an illustrated cam install guide:
4th Gen LT1 F-body Cam Install
http://shbox.com/ci/sprockets.jpg
http://shbox.com/1/cam_timing_ani.gif
This is #6 TDC.
....I followed the procedure in "How to Rebuild LT1/LT4 by Mike Mavrigian" when I assembled my short block. Both #1 and # 6 pistons are "up".....when I installed the top end and proceeded to lash valves I then rotated motor so both I & E valves on #1 were closed and started on #1 cyl for the valve lash
apologies for assuming #1 was TDC following the procedure in the book...as it was #6
I think the author advised doing it that way so it is easier to see the dots top gear being at 6 and bottom gear being at 12 to see alignment better vs having both gear dots at 12 position....
Yeah, dots together are easier to visualize and is the most common way to set the gears. If you were doing a traditional, old school SBC, dots together would be #1 TDC (at least I think I remember it being that way ) .
Yeah,that had me scratching my head when I rebuilt the LT1 and work out which cylinder the opti was pointing to.
