1995 z28 intermittent stumble
Old Mar 15, 2005 | 10:36 PM
RCF925's Avatar
I have a buddy whose 95 z28 with 6sp will intermittently cut out when you are driving it. You will be going along and it will kinda of buck and you lose all power for a second then the next second it will be fine. It doesn't do it at an idle but will do it at anytime will you are drving. anybody have suggestions on what might be the problem.
Old Mar 15, 2005 | 10:44 PM
MackZ's Avatar
Re: 1995 z28 intermittent stumble
What did he check so far? I would think a bad plug wire or ignition coil
Old Mar 16, 2005 | 07:14 PM
RCF925's Avatar
the opti is brand new, the plugs are new, new fuel filter, new coil and icm. I dont know what could cause this.
Garcia5
Jul 7, 2022 06:51 PM
calaban
May 18, 2020 06:43 PM
edxiel
Jan 24, 2015 07:40 PM
Jan 5, 2015 07:14 PM
