1995 z dont run.
Old Jun 8, 2007 | 11:51 AM
tman78's Avatar
1995 z dont run.
Ok, well I have a 1995 z28, and about 2yrs ago I got some work don’t on it. I got zz9 cam, cold air, heads ported and polished, thermostat, computer programmed. Well since then my car hasn’t ran right for a long period of time. I have had to change my distributor, like 3 times, and they work for about 2 months, then my car starts to miss fire, and bogs down, then it will just start up then shut right off. Sometimes when I would be driving and I would get on it, it would just stop; die on me right when I got on it. Does anyone no what could be wrong with my car. I would so much appreciate it, I have looked around and I just can’t seem to find someone that can help me. Thank you for your time....
Old Jun 8, 2007 | 12:03 PM
2000GTP's Avatar
You mentioned you have gone through 3 optis in a short time frame and you recently cammed the car. The first thing that comes to mind is do you have the correct opti drive pin length on the camshaft?
Old Jun 8, 2007 | 02:20 PM
tman78's Avatar
Thanks for the reply, would you no how to check the length?
Old Jun 8, 2007 | 02:41 PM
Heatmaker's Avatar
Advanced Member
ZZ9 Can. Is that Lt-1 compatable?
Old Jun 8, 2007 | 02:44 PM
Heatmaker's Avatar
Advanced Member
you can measure the dowel pin length compaire it to stock.
Old Jun 8, 2007 | 02:48 PM
tman78's Avatar
Ya.
Parts Wanted
May 1, 2016 10:25 AM
magman
Apr 15, 2016 03:08 AM
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
