1995 Engine Harness Discrepancy
Old Nov 2, 2005 | 09:30 AM
sweetride45's Avatar
http://shbox.com/1/harness_connector_faces.htm
http://shbox.com/1/1995_pcm7.jpg
Ok, I'm working on the harness part of my engine build-up to put in my '90 'bird...while tracing wires, I came across two different descriptions, for what apparently is the same wire.
On the connector face diagram, I'm looking at H-C230 Light Blue/Black (Automatic) TCC switched power feed
On the PCM pin-out, when I probe back the PCM connector to that wire, it is on C14 Light Blue/Black Brake Signal
So, my question is, does this get spliced to my brake signal, and they are just labeled two different things? What is the correct use for this wire?
Thanks guys!
Old Nov 2, 2005 | 03:07 PM
Re: 1995 Engine Harness Discrepancy
I have reason to believe it's the TCC wire, but if so, why does it trace to C14 at the PCM? One of the two charts has to be labeled wrong.
Old Nov 2, 2005 | 05:37 PM
Not labeled wrong, just two different labels for the same thing. The PCM says it is a "brake signal" input and that is just what it is-from the TCC interrupt contacts in the brake switch.
Old Nov 2, 2005 | 06:53 PM
Shoebox...thanx for clearin' that up!
calaban
May 18, 2020 06:43 PM
willismoons
Feb 14, 2015 08:42 PM
Jan 5, 2015 07:14 PM
joe777107
Dec 1, 2014 09:32 AM
Jul 4, 2005 05:00 PM
