1995 camaro Z28 Sat for 7 years
Old Feb 28, 2014 | 10:53 AM
nmarinelab's Avatar
Cool 1995 camaro Z28 Sat for 7 years
Hello - I have a 1995 Chevy Camero (15,000 miles) that has sat for over 7 years. Not started that whole time. I know it has fuel in the gas tank - and it started fine when I parked it - but wanted to know if anyone has any advise before I put a new battery in it and try to start it up again. Should I drain the tank? Clean the injectors? Not sure if the gas was before the ethanol change or not and don't want to mess it up if I do not have to.
Old Feb 28, 2014 | 11:20 AM
JFR's Avatar
JFR
Re: 1995 Camero Z28 Sat for 7 years
Hi , 1995 Camaro z28. Sat torn apart for a blow gasket for 7 years. Just put it back together last year. Ended up, new fuel pump, fuel regulator. When I parked it, had fuel in tank, when I took apart for new fuel pump, was empty and was clean. I ran a lot of clean gas thru the system,got it running. I would also check your spark plugs. do a search on here for fuel pump, tanks etc and should find info on cars sitting for a while. I should have added, check the LT1 Tech forum.
Old Feb 28, 2014 | 11:56 AM
95 Z/28 LT1's Avatar
Super Moderator
Welcome to the board. You should try posting this in the LT1 Tech forum to get the right people looking at it. I can move this thread over if you want.
Old Feb 28, 2014 | 07:42 PM
TedH's Avatar
Re: 1995 camaro Z28 Sat for 7 years
Welcome to the board. Please check the tech forums.
Old Feb 28, 2014 | 09:05 PM
Chevy Cust Svc's Avatar
Originally Posted by nmarinelab
Hello - I have a 1995 Chevy camaro (15,000 miles) that has sat for over 7 years. Not started that whole time.
nmarinelab,
Welcome to the forum! Glad to have you .
William R.
Chevrolet Customer Care
Old Mar 6, 2014 | 01:55 PM
nmarinelab's Avatar
Thank you and everyone else for the suggestion to move this over to the Tech Forum - I would appreciate it if you could move it over since I can't figure out how.
Old Mar 6, 2014 | 01:56 PM
nmarinelab's Avatar
Thank you - I will do what you have suggested! New tires ordered.
Old Mar 12, 2014 | 10:25 PM
dark-evader's Avatar
change the oil, put some Marvel Mystery Oil & sea foam in good to go...Chevy runs deep!
Old Mar 12, 2014 | 11:56 PM
4th Gen 4 Life's Avatar
You should really sell it to me.. lol 15k miles thats nice. Almost like a barn find like the 69 era muscle cars. I bet the condition of the car is flawless.
My suggestion tho would be to drain the fuel and try to get some oil into the plug holes because those cylinders should be dried out. There was a post about draining the fuel ill try to find for ya.
Sent from my DROID X2 using Tapatalk 2
Old Apr 9, 2014 | 03:59 PM
nmarinelab's Avatar
Ha - my boyfriend said I should sell it!! - Its not flawless - its a convertible so will need a new top and carpets cleaned up - but other then that its nice! Can't wait to drive it again! Thank you for finding the link to drain the fuel - I do not want to put a hole in the fuel tank if I do not have to.
Old Apr 9, 2014 | 04:07 PM
nmarinelab's Avatar
95 Z/28 LT1 thank you for the suggestions - can you move my issue to the L1 tech forum since I can't figure out how?! please
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
Chrisdude
Jul 24, 2002 02:25 PM
Jake77444
Jul 21, 2002 05:37 PM
2000silverz28
Jul 20, 2002 06:14 AM
