1994 z28
Old Feb 18, 2008 | 09:53 PM
xzodion's Avatar
1994 z28
Hey, im goin got look at a 1994 z28, ive never owned a lt1 what are some of the more comon problems i should be looking for? and any other warrning i should look out for.. any advise would be greatly appreated..
thank.
Niall
Old Feb 19, 2008 | 06:40 AM
2000GTP's Avatar
The optisparks(distributors) are what have the worst reputation for the LT1s, especially on that particular year where it is a non-vented design. The rear intake manifold is notorious for oil leaks and the power window motors, if so equipped, are subpar and common for failures as well.
Old Feb 19, 2008 | 07:50 AM
ss.slp.ls1's Avatar
Check for oil leaks, as GTP said, rear of the intake manifold is a common place. Check for coolant leaks, look at where the water pump sits flush against the block, look at the bottom of the water pump, there is a little "weap" hole, see if any coolant is coming out of it. As usual, check for any weird noises: knocks, ticks, etc. If you are not familiar with the engine, have someone who is check it out for you. Good luck.
Old Feb 19, 2008 | 03:08 PM
xzodion's Avatar
Awsome guys thanks for the info..
Old Feb 19, 2008 | 04:07 PM
BUBBA's Avatar
Number one is who are you buying it from: original owner, used car lot, kid, adult, et al. This should at least put you in the right frame of mind as a place to start.
Number two: With a car that old, you are going to get what you see and feel. I.e. what does it look like, i.e., condition, inside and out. And how does the engine sound and how does it run.
Are there any documents regarding repairs, maintenance, mods, etc.
If it checks out as far as condition, both looks and drivability and you aren't getting it from a gypo car dealer, or a kid, then you might be lucky.
If the two suggestions up top don't check out, run like the wind, JMHO
Noenav
Mar 1, 2019 07:38 AM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
cmdeshon
Jan 4, 2015 11:15 AM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
