1993 timing set
Old Oct 13, 2006 | 09:17 PM
19camaro71's Avatar
1993 timing set
i did the search and all i found was a cloyes setup and the extreme duty timing set. My question is what timing set can i get and keep my mechanical water pump(its fairly new) and current opti (its a new MSD unit) for my 1993 formula?
Everything i read says i need to change opti's to a vented setup when using extreme duty and i have already bought the new MSD unit for my current setup, and i want to keep the water pump intact (i'm on a TIGHT budget here, as i am in high school)
I plan on a LE1 w/ LE2 cam package this winter and everything is set except for which timing set i need to get. (BTW the car as 88000 on the stock block) Thanks!
Old Oct 13, 2006 | 09:26 PM
Re: 1993 timing set
A stock set is all you can do on a tight budget.
Old Oct 13, 2006 | 11:50 PM
19camaro71's Avatar
Re: 1993 timing set
will a stock set (i assume a stock replacement) be stout enough for the package i plan on running? It won't see anything north of maybe 6200 when i take it to the strip a few times...
Old Oct 14, 2006 | 05:07 PM
marshall93z's Avatar
Re: 1993 timing set
Should be.
HectorM52
Jul 30, 2017 11:46 AM
jb4xx
Feb 2, 2015 10:00 PM
Jan 23, 2015 01:13 PM
Sarahrope64
Nov 27, 2014 11:17 AM
