1993 LT1 Stalling
Old Jan 12, 2010 | 06:14 PM
LucasZ's Avatar
1993 LT1 Stalling
I installed the Delteq Opti-Direct in my 1993 LT1 Camaro Z28 about 5 years ago. The control module and coils were installed on the valve cover with heat shield as instructed. It’s been running great until today between home and work, a 3 mile, 10 minute drive.
Drove to work in the AM. No problem.
Drove home for lunch 4 hours later. No problem.
1 hour later, started driving back to work. Half way through the trip, the ignition cut out. No stumbling or indication that it was about to go. I was in a lower gear, accelerating at a low RPM when this happened. Radio and all the other electrical components continued to operate. On first try, the car started back up and ran smooth.
A mile and 3 minutes later, it cut out on me while accelerating in second gear. RPMs were about 3500. Symptoms all appeared the same. Radio still running. While coasting, I tried to start the car. It cranked but didn’t fire up. Coasted into a parking spot and sat for all of 20 seconds. Tried again and it fired up, getting me the remaining 1 min drive to work.
There are no OBD codes being triggered. The SES light is not on. Since it’s a 93, I can jump two OBD pins to flash any stored codes. It came out clean. I watched it repeat code 12 about 6 times to be sure since it flashes that 3 times for a self diagnostic indication.
A lot of what I’m finding in the forums points to ignition control module and coils, but I’m using the Delteq system which uses the Delphi ignition module and 4 coils on the valve cover. I'm unsure if it’s probably the same problem.
Thoughts?
Old Jan 12, 2010 | 07:36 PM
n2ceptor's Avatar
Since Delteq is out of business, I don't know if there is any info..... You are not the only one.... Form what I understand, most went back to OPTI, or upgraded.....
Old Jan 12, 2010 | 09:03 PM
LucasZ's Avatar
I searched the forums and found threads about the Delteq unit itself failing after 20-30k miles of being exposed to heat. And of them not being around anymore. Ouch. Is the behavior I'm experiencing a typical precursor to complete failure?
jb4xx
Feb 2, 2015 10:00 PM
camy 1993
Feb 1, 2015 07:16 PM
93440supernat
Jan 12, 2015 06:35 PM
Sarahrope64
Nov 27, 2014 11:17 AM
