168 Tooth Flexplate and Starter Issues
Old Jun 27, 2007 | 09:28 AM
96ZRDR's Avatar
Desperetely need your help!
I recently had my engine rebuilt, but through miscommunications, my builder installed a 168-tooth flexplate instead of the factory 153 tooth. I did not find out until I tried to install the factory starter, and it makes contact with the flexplate about 1 inch before sitting/aligning itself with the engine block.
Just wondering if anyone know which starter would work with a 168 tooth flexplate and clear my Hooker Long-Tubes as well?
Would need part numbers and where to get.
This is a 1993 TA.
Thank You.
Old Jun 27, 2007 | 10:05 AM
96ZRDR's Avatar
Sheesh, thanks a lot!! Cheap as hell too!
Do you know if it come with its own special bolts/shims, or can I use the factory bolts.
Really appreciate it!!!
Old Jun 27, 2007 | 10:09 AM
96ZRDR's Avatar
Thanks a lot, I purchase it and try it out today!! Getting close firing up this baby and take it in for a dyno tuning session.
Thanks again!
Old Jun 27, 2007 | 01:54 PM
96ZRDR's Avatar
Autozone states its w/o a solenoid. What does that mean for me? Do I have to swap solenoids??? Just confused.
Old Sep 6, 2007 | 02:09 PM
Bill(AR) 96T/A&93 Formula's Avatar
I am having the same issue, did you get this figured out?
Old Sep 6, 2007 | 04:37 PM
96ZRDR's Avatar
nope it worked perfectly, no shimming. All I had to do was enlarge the "hole" diameter of the cable from the battery for it to fit the larger post on the starter solenoid.. (fat one).
Old Sep 6, 2007 | 05:27 PM
chief455's Avatar
I don't see any part number posted? did the starter mount in the outer, diaganol holes in the block?
Old Sep 7, 2007 | 07:33 AM
96ZRDR's Avatar
I dont know what happenned to the other guys posts. They somehow got deleted off this thread. Part # 3510 at your local autozone. It is $29.99 + $15.00 core.
I am not sure if this will work with stock exhaust, and it was a tight fit with Hooker LT's.
You will need to get an additional long starter bolt, the short one will not suffice. They sell them at Autozone too. I believe it bolts up using the same holes as in the stock starter.
link below
http://www.autozone.com/R,APP70575/v...ductDetail.htm
Good Luck
Old Sep 7, 2007 | 10:45 AM
chief455's Avatar
link below
Good Luck
thanks!
Old Sep 10, 2007 | 09:02 AM
The one I ended up getting was the #03-0485 gear reduction starter from Oreilly's http://www.oreillyauto.com/EW3/Displ...cycleCount=962. This one was smaller and much more powerful than the standard ones and fit right in with my headers. They wanted 124.99 and a 50 core charge but I had them call Autozone and they price matched the 89.99 and 20 core that Autozone had. The starter uses the two longer bolts and they are the staggered (diagonal) holes. Everything bolted up great and man does that thing crank the engine fast and start fast. I had used a cheapo standard starter before and it didn't last long from the heat, this one has a lifetime warranty.
HectorM52
Jul 30, 2017 11:46 AM
Sauced
Apr 29, 2015 08:31 AM
cmsmith
Apr 1, 2015 07:36 AM
Newgmman
Feb 25, 2015 02:53 PM
