160 thermo. question
Originally posted by Eliminator
With everybodies opinions its hard to tell whats, what. I was told the car will reach peak power fully warmed up with factory set thermo. its what it was designed for, is that true?
If you wanted to leave the stock 180º thermostat in, I would at least have the fan programming altered so they would come on at a lower temp.
Here is something you can read that might give a little more insight.
Originally posted by shoebox .
If you wanted to leave the stock 180º thermostat in, I would at least have the fan programming altered so they would come on at a lower temp.[/B]
My Z seems to be running a lil too hot(just below the red, cooler of course on the highway, but it doesn't go under 200; or the needle stays right about in the middle.) Does that seem too hot to anyone?
Originally posted by htweels86
Would you just take it in to a mechanic to get that done?
That is definetely not true...many car run that cold at hwy speed for hours at a time.....from factory settings, the only disadvantages to installing a 160 are:
a. in the winter your screwed b/c it takes much much longer for the heater to work
b. b/c of the factory's setting w/fans no coming on tell 226, it conflicts and does not work as well as if you had the fans reprogrammed as well, but just the 160 is still better then everything stock....
