160 T-stat not 160?
Old Dec 5, 2006 | 11:57 PM
Texas_96_Z's Avatar
160 T-stat not 160?
Can someone enlighten me as to why my car runs at 170-175 degrees (even while cruising) when I installed a Hypertech 160 degree thermostat?
Old Dec 6, 2006 | 12:07 AM
edman's Avatar
Thermostat timing.
My 170 degree stat starts to open at 170 degrees and is fully open at 180 degrees when I bought and checked it. The old 180 degree stat started to open at 180, but wasn't fully open until 195 degrees. I would say that your 160 degree stat only starts to open at 160, and most likely isn't completely open until about 170 degrees. So, it seems that they might all be rated at just the beginning of the opening timing.
Old Dec 6, 2006 | 02:36 AM
Ironxcross's Avatar
mine does that too, its working fine
Old Dec 6, 2006 | 07:03 AM
BoozrCruzr's Avatar
Keep in mind that the 160 rating is only when it starts to open. Air flow, radiator age (clogging), timing, fans etc. all decide on how hot your car gets as well. Your car isn't going to sit at 160 all day long juse because you throw a 160 t-stat in there...especially if you are sitting in traffic or beating the car hard.
Old Dec 6, 2006 | 07:17 AM
Because that's the way it works. It begins to open at 160°. Your old 180° thermostat did not keep your engine at 180°, either (more like 190°-195°), in the same conditions.
Old Dec 6, 2006 | 08:06 AM
Sweetred95ta's Avatar
Is this for an LT1? I've never seen a 170* thermostat for an LT1.
Old Dec 6, 2006 | 02:40 PM
Texas_96_Z's Avatar
Thanks for the responses guys.
Shoebox has spoken.."Because that's the way it works!"..all hail Shoebox...
Old Dec 6, 2006 | 02:47 PM
speed_demon24's Avatar
My car always runs at 173 (scanmaster) with my 160 degree thermostat with a becool.
Old Dec 6, 2006 | 08:25 PM
Pokey's Avatar
"I've never seen a 170* thermostat for an LT1."
LT1 170* in the Summit Cat., from BeCool.
Old Dec 6, 2006 | 09:12 PM
Dang, right. You won't get an answer like that from Injuneer!
G-BODYT56
Jan 14, 2022 11:14 PM
chevy94c
Mar 26, 2016 08:53 AM
HarleyZ28
Oct 5, 2015 06:23 AM
tdigger9899
Sep 7, 2015 10:56 AM
Fastbird93
Jul 28, 2002 09:14 AM
