160 hypertech?
Old Mar 22, 2004 | 08:19 PM
kyzar24's Avatar
160 hypertech?
anybody else have this problem i have a 94 z28 and my friend has a 99 z-28 we both put 160 hypertech thermostats for our cars in our cars and there are no running temp differences 210 or higher when sitting is this normal?
Old Mar 22, 2004 | 08:24 PM
Kataklysm's Avatar
Mine never goes over 170-175. You probly have an air pocket in the cooling system, try bleeding it.
stereomandan's Avatar
Thermostats only make a significant difference when you are moving. It opens up to allow cooler coolant flow through the engine and the moving air cools the radiator fins. If it opens when the car is idling, there is no way to cool the coolant unless the fans kick on eventually.
Take it for a drive and you will see that the engine temp stays low instead of 180-190.
Did you open the bleed valves after the engine was warm and let the air out?
Dan
Old Mar 22, 2004 | 08:25 PM
z71camaro's Avatar
Did you change the fan temp settings? If not the t-stat will only make a diff while your driving.
Old Mar 22, 2004 | 08:26 PM
white97z/28's Avatar
Don't know if it is or not. Some people on here will tell you that you need a tune and some that have done it say you will not need a tune. Personally, my views are the computer is designed to work with the stock thermo, which is 195 correct me someone if im wrong. If you drop it down to 160, that tells the computer the engine is cold so it dumps more fuel to the injectors. It wont run right and will kill your gas mileage, you may see temp drops or you may not. I would say you would need to get a computer tune, either by pcmforless, or HPP3 if you can afford it.
Old Mar 22, 2004 | 08:47 PM
kyzar24's Avatar
yes i bled the valves it stays like 160 170 while driving but sitting it goes to 210 and up my manual says the fans dont come on till 228 what the hell that is too hottttttt
Old Mar 22, 2004 | 08:49 PM
Just a tip. A lot of times I will turn the AC on when I am sitting at a light, or when I'm just idling somewhere. It drops the engine temps right away. I turn it back off when the light is starting to turn green. I think the AC system turns the cooling fans on sooner. It will keep the engine temp around 190.
Dan
Old Mar 22, 2004 | 08:51 PM
z71camaro's Avatar
It is too hot but unfortunately that is the stock settings. You need the fan mod to make it come on sooner but I don't know if there is one for the newer ls1's but without that or a program it will continue to run hot.
Old Mar 22, 2004 | 10:22 PM
ftransam1's Avatar
Mine does the same thing. Around 210-220 at idle and then 170-180 while driving. Turns out the coolant fans aren't coming on. Something happened to them after I got the car tuned for my cam. Just had the file re-done and installed and now it works fine.
Old Mar 22, 2004 | 10:30 PM
ROADRAGE's Avatar
Please dont ever give tech advice again.
Old Mar 22, 2004 | 10:36 PM
Punkillr's Avatar
the stock thermostat is 180*
G-BODYT56
Jan 14, 2022 11:14 PM
chevy94c
Mar 26, 2016 08:53 AM
colts0455
Sep 4, 2015 01:41 PM
colts0455
Jul 24, 2015 04:51 PM
