15-20 RWHP with less than $200
Old Mar 22, 2006 | 08:50 AM
TransAm2k4's Avatar
I ran a back to back dyno comparison of the Electric Cut Out opened and closed and i saw a difference of 15 hp everytime consistently and even in 2 different dynos. Also once so a increse of 19 rwhp. All this with a flick of a switch. All i can say is wow! It sounds awesome too, just watch out for cops. I think the simple fact that i have all those mods helped the power gain when opened then i also have a 3" cat-back allready so its on top of whatever the cat-back gave me. Maybe later on i might put the graph on. One of them you can see an increase of 34 rwhp but that was open and tunning.
Old Mar 22, 2006 | 12:42 PM
Chrisbequick's Avatar
Re: 15-20 RWHP with less than $200
You got a cutout, an electric valve, and installation for UNDER $200?
-Chris
Old Mar 22, 2006 | 01:01 PM
1SlowFormula's Avatar
I ran back to back dyno's with mine, full stock exhaust and with the cutout open... The graphs kind suck because the dyno operator was shutting it down early because he didn't believe me when I told him to set the dyno to record until 162 in 3rd gear, and I only got to 5K (~140 MPH) on the first one and 5250 rpm (~150 MPH) on the next...
Full exhaust
Cutout open
*** EDIT *** changed text above to read beter...
Old Mar 22, 2006 | 01:10 PM
roughneck427's Avatar
I see you are running the Edelbrock Cat back just like i am your not the only one ive seen that gained 20 hp at the wheels with this cat-back using a cut-out. A guy on LS1tech said the same thing im putting mine on today after work and headed back to the Dyno to see the results
Old Mar 22, 2006 | 02:14 PM
FivePoint7z28's Avatar
What cut out are you guys using? QTP?
Old Mar 22, 2006 | 02:22 PM
cndctrdj's Avatar
also where is the cutout
before or after the cat
Old Mar 22, 2006 | 03:17 PM
Mine was made at my local exhaust shop, cost me about $30 though and it's not electric, and is located right before the exhaust goes over the rear axle...
Old Mar 22, 2006 | 03:24 PM
cndctrdj's Avatar
if you put it before the cat i bet you would see a few more hp
i had a fiend who had his at the end of his headers and it was a very very loud setup
Old Mar 22, 2006 | 04:52 PM
2000GTP's Avatar
19rwhp with a 200 dollar investment, not to shabby.
Old Mar 22, 2006 | 07:45 PM
Jeremy95TA's Avatar
Awesome. I wonder what dual cutouts would yield...?
Old Mar 22, 2006 | 07:50 PM
96speed's Avatar
30rwhp. Makes sense to me!
j/k
Ryan
Old Mar 22, 2006 | 08:01 PM
Skull Leader's Avatar
Arrow Re: 15-20 RWHP with less than $200
Me too. The shop that did mine didn't know what a cutout was even after I explained it, so they just cut a hole in the pipe and welded a 3" tube on that, then, welded a peice of collector flange to that. Then made some kind of strange cap for it. I have no reason to ever cap it though.
Old Mar 22, 2006 | 08:10 PM
HardcoreRM125's Avatar
Hahah at first I thought that was his dyno the guy who started the thread with a CC306 heads and ported intake and i was like WTF is wrong with the car those numbers are like a bolt on only car ...
Then I realized the ywere from a bolt on only car lol
Old Mar 22, 2006 | 08:46 PM
Yeah, sorry to confuse anyone, but figured I had the same experiance and had mine online already, I would back the guy up in case a bunch on nay-sayers got on this thread...
Old Mar 22, 2006 | 10:22 PM
Some really nice numbers for you for what mods you have btw.
