132,000 Miles on Injectors. Do they need replaced ? Details inside.
Old Nov 14, 2004 | 12:25 AM
Lt1t56's Avatar
My Z now has 132,000 miiles and for the second year in a row it failed emissions test for inspection (HC), scanmaster readings seem fine, resistance seems fine on injectors and when I pull fuel rail and pressurize fuel system no drips of fuel noticed from injectors. Fuel pressure is in specs with regulator hooked up and not hooked up. Is there anything else I should check injector wise to determine defective injector ?
I love this car and dont mind spending the money for new injectors to fix the problem but this is the last year that Iam going to hastle with trying to pass emissions and I dont want to start robbing parts off my T/A since it passes inspection fine.
Any help is appreciated, in the mean time I will be looking in the auto trader at late model LS1 F-Bodies and 98-99 C5 vettes for a resolution to my problem.
Old Nov 14, 2004 | 12:44 AM
94Zman's Avatar
Re: 132,000 Miles on Injectors. Do they need replaced ? Details inside.
Yes, just did that and passed, see my post on the huge thread of 'hesitation off idle'
Old Nov 14, 2004 | 01:58 AM
amean94ta's Avatar
you can also have them cleaned for $25 each if you dont need a larger injector
Sergio
Jan 27, 2016 04:27 PM
Jazsun
Dec 29, 2014 12:14 PM
mspennyhughes
Nov 28, 2014 03:22 PM
