13.27 @107mph with a 2.0 60"-What next?
Old Aug 23, 2008 | 07:23 PM
Sweetz28_72's Avatar
I am looking to take the next step with the Z. I have every single bolt on imaginable include airfoil and Meizere Water pump. I have goon as fast as 13.27 with stock suspension and stock size tires(245/50/16). I need to know if I should go with a Heads and cam Package or Power adder. I plan on rounding up all the parts before Winter so I can pull the engine if need be while shes down for the winter storage. What do you guys think I need to do?
....PS stock rearend still lives even though shes bleed some Gear lube out the Pinion seal.
Old Aug 23, 2008 | 07:33 PM
Oh and this was speed shifting the car
Unfortunately along with the possibility of pulling the motor and I will be rebuilding the trans this time because I am having trouble the 5th/6th gear syncro assembly
Old Aug 23, 2008 | 08:07 PM
SS MPSTR's Avatar
tires, hal qa1's and more seat time....your short times need a ton of help. you have the mph to get deep into the 12's.
Old Aug 23, 2008 | 08:13 PM
camarozz95's Avatar
+1
def. get tires your trap speed is very high 12's should easily be attainable with some practice.
Old Aug 23, 2008 | 10:31 PM
<Puck>'s Avatar
Suspension and tires.
You should be at least in the mid 12's with that and some more practice.
Old Aug 24, 2008 | 08:01 AM
Well thanks guys, thats what I was wondering....It is a mother to get this thing down the track with limited wheel spin....I think I might get some Lower control arms with Relocation brackets(due to the car being lowered) and I am looking into getting Black 17x9 and 17x11 ZR1 wheels with some Nittos on the back or ET streets
Old Aug 24, 2008 | 08:07 AM
Due you guys think it would be worth anything to me to get a mail order tune for my car as it currently isnt tuned
Old Aug 24, 2008 | 08:08 AM
<Puck>'s Avatar
I think that will help you a lot more then you think.
Old Aug 24, 2008 | 11:34 AM
SS MPSTR's Avatar
Absolutely - the IC is probably several feet behind the car at this point.
Old Aug 24, 2008 | 11:38 AM
SS MPSTR's Avatar
For track use, look for a set of used Welds (15x4, 15x8) and get some ET streets for the rears, with bias ply front runners. Reducing unsprung weight is key, and the ET streets will have better traction than any Nitto.
And practice. You'll be ecstatic once you get your short times in the 1.6-1.7 range, then you'll be running deep 12's.
Old Aug 24, 2008 | 11:44 AM
I'll keep an eye out for a set of welds, next payday i plan on picking some things up-Havent been to the strip this year because its been unbearably hot in OH
Old Aug 24, 2008 | 12:00 PM
ssclone's Avatar
gears and slicks. and a good 60. keep the motor stock. does it have a tune?
aaron
Old Aug 24, 2008 | 12:03 PM
aaron
No tune, just what GM told it to do
Old Aug 24, 2008 | 04:56 PM
Jazsun's Avatar
Damn thats running pretty good. I wish mine ran that good. How is that shifter? I have a hurst and I think its a p.o.s The springs suck or something as its really hard to hit 3rd while racing.
Old Aug 24, 2008 | 04:59 PM
They shifter is my favorite mod-havent missed 3rd since the install-Yeah I have been told by my friends that they think I have a factory freak because I can beat up on the local LSX cars running around here
