12 Bolt or 9 Inch??
Old May 8, 2003 | 06:03 AM
Fastbird93's Avatar
Question 12 Bolt or 9 Inch??
Car is going to be set up with parts still waiting in sig. It's still considered a "daily driver" although it sees more track time than street time any more. Which is better for street driving, or do they make a difference? Also, can the 9 inch have ABS put on it, because that will be all I need to know really. I'm not getting rid of my abs.
Old May 8, 2003 | 06:37 AM
IDOXLR8's Avatar
If you car is an everyday car I would recommend going with a 12 bolt. I just installed a Moser 9-in in my car and had to disable my ABS. I was told by Moser the only way to get a 9-in to work with ABS is if you run a 4- channel setup. Your 93 rearend is setup for 3-channel.
Victor Lamb
Aug 26, 2017 02:52 PM
maybe2fast
Mar 16, 2015 09:45 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
