11's possible??
Old Apr 18, 2007 | 05:31 PM
ChevyTuffD.A.'s Avatar
11's possible??
I ran 13.02 at 106.4mph last time at the track. I was getting really bad wheel hop and was cutting 1.9x 60fts. I just got my UMI LCA's in the mail today which I am going to throw on later this week. I also have a 100 shot Zex kit on the car which I have not used at the track yet. If I spray this 100 on it and put on the LCA's, could she go high 11's??? Let me know what you guys think. Thanks. Dustin.
Old Apr 18, 2007 | 05:36 PM
97 LT1formula's Avatar
if you get a 60' around a 1.7 you MIGHT hit 11.9s. but im gonna say low 12s
Old Apr 18, 2007 | 05:38 PM
VK's Avatar
VK
Just read the sig.. i ran a 13.0 all motor 1 run before the run in my sig. That was spraying 150wet ALL the way down the track though.
2000GTP's Avatar
I'm thinking low 12s as well, but you never know.
Old Apr 18, 2007 | 05:54 PM
burnout42's Avatar
this will be a double edged sword my friend.......you may hit the 11's with a great launch, but you might also grenade your rear knock on wood. I hope you are not planning to spray till AFTER the 60 ft. mark........
Old Apr 18, 2007 | 06:08 PM
VK's Avatar
VK
I spray'd 150wet off the line, like RIGHT off the line we slicks. Sock 10-bolt w/ A4.. took it 4 times and its still in my car from last year.
I was shocked.. i expected to break something... i was almost disapointed .. lol
Old Apr 18, 2007 | 07:05 PM
Well, I am not going to spray till I have good traction. Plus I have 2 things on my side. 1. I have an automatic 2. I have Richmond gears, which I heard are a strong gear. I dont think I have good enough traction to be able to spray it right off the launch. But we'll see.
Old Apr 18, 2007 | 07:18 PM
2000GTP's Avatar
Ditch those Nittos and put on some M/T drag radials and you should see some better traction.
Old Apr 18, 2007 | 07:22 PM
As of right now the tires are hooking great. All I am getting is a **** load of wheel hop. I just got my LCA's to help out with that tho.
Old Apr 18, 2007 | 07:24 PM
Jlo's Avatar
Jlo
You never know. I saw this 96Z at the track last friday ran a 10.14 in the quater mile, guy say's it's a stock short block with the LT4 Heads and cam package his suspension and everthing else compliments the car yes he's spraying 150-200hp shot but 10.15 on a stock short block It's unatural.
