11.84:1 Safe on 91??
Old May 8, 2003 | 01:28 AM
SVT Killer LV's Avatar
Like it says...is it safe????
Old May 8, 2003 | 01:40 AM
btw i have a 306 and nice heads
Old May 8, 2003 | 02:03 AM
93turbo5oh's Avatar
on the bottle id want to see about 11.5:1, on motor i would run about 12.8:1.
Old May 8, 2003 | 02:08 AM
ill be bottle fed.. but n2o and compression is good... i dont know how long the motor will last. But should I be ok.. or will it be ping city?
Old May 8, 2003 | 02:26 AM
93turbo5oh's Avatar
the spark plugs will tell the tale. run a colder then stock plug and make sure the engine is about 160* to be safe. pulling out a few degrees of timing will effectively fatten up the air/fuel ratio as well.
Old May 8, 2003 | 02:38 AM
I got that checked.. Autolite 104 waiting to go in
Old May 8, 2003 | 11:50 AM
so i should be ok right?
Old May 8, 2003 | 05:14 PM
Grease's Avatar
I have 11.86:1. I use pump gas and have no knock retard. So you should be fine.
Old May 8, 2003 | 07:42 PM
93turbo5oh's Avatar
on nitrous?
rideordie
Sep 7, 2015 08:22 AM
4586
Aug 24, 2015 11:04 PM
Aug 7, 2015 08:52 AM
Jul 10, 2015 02:23 PM
Jan 23, 2015 01:13 PM
