11.8:1 Compression?
11.8:1 Compression?
Is there such thing as TOO MUCH compression for a daily driver? Car will able to be run on 93 octane without problems (motor will be driven daily with 94 octane).
Too much compression like things will wear faster/break/CAUSE FOR FIX?
Re: 11.8:1 Compression?
I have heard of people running 13:1 CR without problems running pump gas.
The LT1 is surprisingly good for higher compression than most would think, reverse flow, custom programming, good quality gas and less sensitive Knock sensors make a big difference.
At least, that's what i've been told.
Originally Posted by ChrisUlrich
But i'm saying will higher compression cause parts to wear faster?
About the only thing its hard on is my wallet with 93 premium goin for about 2.47 a gallon and well.... the car isn't real "fuel efficient", course... I think I was wearin lead shoes. Lloyd and Bret both
Originally Posted by 94zgreenmachine
Are you freakin from your other post when someone said we'd be breakin stuff alot with that compression. I got looks from everyone when I told them what my compression was, including my engine builder. Lloyd Elliot assured me everything would be just fine. Bret designed my cam and this thing pulls like a ****. I was shocked a bit when I saw what the specs were. I was way off, but I am no cam expert either. Before they would do anything I had to get the deck height, piston volume and head gasket to get my quench right. My quench is at .036 and Lloyd said it would be perfect.I had faith in those guys and they haven't let me down. When put to a scan tool it shows no timing being pulled out and this thing runs rich and I desperately need my datamaster to show up soon!!!! It's got more power, I just need to tune it some more.
Thanks for the info
Damn,Bret finally got brave and put the quinch at the narrow end.Way to go Bret.
He's always recommending .040+.
Originally Posted by Gripenfelter
I run 11.8:1 compression on 92 octane with no problems.
My friend is insisting that I can't run 11.8:1 compression on pump gas without pulling a serious amount of timing and losing a serious amount from the high compression motor.
Also insists that nitrous on pump gas is a complete no no
How often you drive the car?
Thanks for the info
Thanks for the info
I drive the car everyday I can. I don't drive it in the rain and my job takes me out of state often but typically 100-150 miles per week.
An important thing to consider is the dynamic compression ratio. That is using the valve timing events. I worked with Lloyd on this as he wouldn't start till he had the info he needed.
) and they decked the block (again
). My piston ended up being .010 in the hole and using the fel pro 5716 .026 we came up with .036 quench. Lloyd said between .035 and .045 would be good but no tighter. Bret was sorta forced to work with it. That would explain the "different" cam specs. I still think its weird but don't dwell much on it cause it pulls like a **** and thats all that counts.
