11.4x or better all motor...who has done it?
Old May 3, 2004 | 05:09 PM
1982z28with18s's Avatar
Must be with HR cam and preferably with stock casting heads. I'm thinking about trying this with my next setup with a 383 with LE3 heads/cam, and some low 1.5 60fts with some weight reduction. I'd like to keep it a daily driver also. I don't think it'd be that hard, but I was just wondering who has done it already and with what setup.
Old May 3, 2004 | 06:13 PM
Fastbird93's Avatar
I can't remember his screen name, but I do believe a guy on here just recently went 11.4X with a stock bottom end, ported heads, and Joe O cam. Hopefully he'll chime in here.
Old May 3, 2004 | 06:30 PM
neil350's Avatar
Ken runs 11.41@117 with a comp cam 230/236 and combo motor sports heads Lt1 in a auto car. Still has a 10 bolt and a 4l60e.
Old May 3, 2004 | 06:35 PM
96speed's Avatar
Local guy runs 11.40s @ 121 on motor (A4) with GTP heads, a GTP6 cam, and a 396ci motor. This is off the footbrake (doesn't flash because of stock rear). Soft 1.6s.
Ryan
Old May 3, 2004 | 06:41 PM
Eff's Avatar
Eff
Re: 11.4x or better all motor...who has done it?
I havn't taken mine to the track yet due to a few complications with the oil pump.
but a friend with a similer setup ran 11.4
383, LT4, 3500 stall, Nitto 555's
Old May 3, 2004 | 06:44 PM
Fastbird93's Avatar
He's got to have some slamming 60' times, right?
Old May 3, 2004 | 06:46 PM
faded93bird's Avatar
heck theres a guy running 11.4xxxx on stock heads
Frank95z to be exact
Old May 3, 2004 | 06:56 PM
Fastbird93's Avatar
Yup, Crane 210/224 or something like that for the cam. Not exactly the most streetable thing from what I hear though (severe weight reduction). But doing it none the less.
Old May 3, 2004 | 06:59 PM
SAR2K's Avatar
Thumbs up
11.26 @ 118.94
Stock bottom end, ported factory LT1 castings, 1.94/1.50 valves, hydraulic cam, A4 3.73's.
Setup really needed 4.10's for some LOW 11's.
Race weight was 3570.
Steve...
Old May 3, 2004 | 07:03 PM
squinn's Avatar
My old 350 motor went a best of 10.54 @ 129, with a 240/250 hr cam, ported stock lt1 heads, about 3350 lbs
Old May 3, 2004 | 07:04 PM
Schurters LT1's Avatar
Originally posted by SAR2K
11.26 @ 118.94
Steve...
What kind of cam in the car??????spec's
Old May 3, 2004 | 08:43 PM
Quickshotkimber's Avatar
Ran 11.4s with stock bottom end, stock ported castings, custom cam and 3600 vig. Those were just shakedown passes. The car had stock suspension and cut 1.52 60s with a 3.73
You should easily be able to run low 11s with a stroker on pump gas. I would think some 10s
Old May 3, 2004 | 09:56 PM
10's is the true goal, and to do it driving to the track and not removing anything when I get there. A local guy is selling a 383 with the LE3 package for a good price, otherwise, I'd just do a 355. I want to do it with Lloyds heads/cam, a 4l60e and a 10 bolt. My current setup is running 11.84 at 114.7 with stock bottem end, Lloyds heads, and a small Joe O. cam (~220/226) and a crappy 1.65 60ft.
SAR, did you do it as you could drive it everyday or was everything out of it and no belt?
So, has anyone hit 10's on yet on with a HR and stock casting heads in a 4th gen in what could be a daily driver?
Old May 3, 2004 | 10:02 PM
Fastbird93's Avatar
You're the one I was thinking of in my first post. I remember seeing you on the EFA forum also.
Old May 3, 2004 | 10:08 PM
Gonna give it a shot. More gear, susp, and some cool wether maybe
