10w-30 or 5w-30
Old Nov 26, 2003 | 07:13 PM
Terran2k's Avatar
10w-30 or 5w-30
I switched to mobil 10w-30 this spring, now it's cold again here in nyc. should i go back to 5w-30 for the winter? or stick with 10w-30? thank you
Old Nov 26, 2003 | 07:16 PM
Birdman7389's Avatar
I'm no expert, but thinner oil flows better when its cold. I just swithed from 10w to 5w30 Mobil 1 this weekend
Old Nov 26, 2003 | 07:28 PM
Fuels94TA's Avatar
I see no problem as long as you stay with the same brand of oil. 5W-30 is design for cold weather conditions. It will be used for 3-4 months of used before it starts to warm up. Then that's when you'll come up on the next oil change.
Old Nov 26, 2003 | 07:48 PM
FastZinTennessee's Avatar
I know it doesn't get that cold here, but I switched to the new Mobil 1 0w40 last oil change. This stuff rocks!! I get comparable cold start up pressure to 5 weight, and great pressure at high RPM.
Old Nov 26, 2003 | 08:08 PM
drewstealth's Avatar
I was wondering this also. Because i live in california where it doesn't get to cold. I'm using 10w30 right now and my pressure always is around the 60 mark. After i drive it for a while it goes down about some but not to much.I was wondering if that would be bad or not. I just changed my oil and put a new k&n oil filter about 1,000 miles ago so i didn't want to have to change again.
Old Nov 26, 2003 | 08:19 PM
Geezer powered's Avatar
can't beat that 0w40w, that stuff rocks, unless mobil comes out with something better
Old Nov 26, 2003 | 11:58 PM
ChrisUlrich's Avatar
Yo
How over in NJ? Where temp gets to about 0 degrees farenheit... below 0 sometimes... not often. What should I be using?
Chris
Old Nov 27, 2003 | 12:05 AM
jasons93z's Avatar
Use 5-30 in the winter if it gets really cold there. Im still using mobil 1 10-30 though.
Old Nov 27, 2003 | 08:38 AM
S.J.S.'s Avatar
You can go either way. Mobil 1 10-30 runs on the thin side anyway.
Old Nov 27, 2003 | 08:51 AM
Joe Bellman's Avatar
Why not just use what Chevy recommends? The designers of the engine probably know more about oil and what oil is best for the LT1 than anyone on this board.
Old Nov 27, 2003 | 10:22 AM
Kataklysm's Avatar
I've been using 5w30 but after the last change and how black it was when it came out, I'm gonna go with 10w30 next time. I tend to get on it alot so the engine chews it up
Old Nov 27, 2003 | 07:53 PM
Because GM also takes into account fuel economy when recommending an oil. Thinner oil=better fuel economy but less protection.
Old Nov 27, 2003 | 11:42 PM
I'm telling you 0w40 is the ****
Old Nov 28, 2003 | 01:09 AM
96Z28TealM6's Avatar
Talking
Geezer powered: okay man we heard ya for the 2nd time
Old Nov 28, 2003 | 01:17 AM
CoUnTryMuZiCZ28's Avatar
Whats wrong with 15w 30?? I used that once i think.. Its the Red cap of mobil 1.. Is that stuff bad or does anyone else here use it??
