1000-2000rpm stumble...Help me plz...
You clean the resistors that span the uprights in the MAF. There are three of them. Be VERY careful when you do this. I used carb cleaner and sprayed mine off and then used the tip of shop towel with some cleaner on it and gently wiped the resistors off!
Good luck!
Good luck!
Originally posted by scoobysnax83
You don't have to take it apart. You can use those long swabs that they make. Almost like a one sided q-tip with a long handle. They sell them everywhere.
Also when you change your fuel filter how do you releive the fuel pressure?
**Now my tip... I prefer not to do it that way. Why? because the fuel spill right on your engine and goes to waste. Also if your engine is hot you really asking for barbecue time. I get a container and get underneath the car with a wrench, and begin to loosen up the nut at the fuel filter and slowly begin to drain the gas down into the container... I changed my fuel filter that way just four days ago. Piece of cake. It wont like spit gass all over the place, not at all.. it will let you control the flow of fuel down to your container.
Marvin
Originally posted by MentalCaseOne
The shraeder Valve on your fuel rail... push a screwdriver in there and fuel will come out.
Marvin
Marvin
lol okay i will be carefull when i do it. I'm gonna go get one today. I'm gonna do it in a couple of days when i get my jackstands back from under my friends car that we are putting a clutch into.
