#1 cylinder not firing! (continued from other thread)
Old Oct 28, 2003 | 09:09 PM
Robert95z's Avatar
#1 cylinder not firing! (is it the opti?)
Well Ive known that my #1 cylinder was misfiring because the exhaust header would be cold at start and the others would be boiling hot...
So heres what I did...
1. Changed the plug/wire... plug was fouled and only 2000 miles on it http://img.villagephotos.com/p/2002-.../Photo0060.jpg
2. Did a spark test by just bumping the starter, #1 got a spark
3. Thought it was a stuck fuel injector so moved #1 injector to #3... #1 still misfiring
4. Wanted to try a spark test again so I unpluged injector #1, had the #1 wire on the opti spark on a plug, grounded to the frame.
What happens? It only gets spark when the car is first cranking up, after that no spark at all!!
We tested out #3 and it gets spark all day so its not a ground problem ...
So im assuming my optispark CAP is bad? Would it be best to replace everything or just the cap? Optispark has original 47k miles
Damn opticraps!!!
Old Oct 28, 2003 | 09:41 PM
dkeers's Avatar
EDIT: Nevermind, I didn't realize that you said it stops getting spark. I would guess opti also. I would replace the whole thing.
Is the PCM telling the #1 injector to fire? Check the fuel injector connector with a noid light. They are like $3 at any autoparts store.
It has spark
It has fuel pressure (since the rest of the injectors work right?)
# 1 injector is fine (it works if in another spot)
so maybe there is a bad connection and the #1 injector is not getting a signal to fire.
If it has good spark, fuel pressure, a good injector, and a signal to fire the injector, I would reccomend a compression leakdown test.
hope this helps
Dustin
Old Oct 28, 2003 | 09:43 PM
Robert95z's Avatar
Originally posted by dkeers
It has spark
No, thats the problem. Its not getting any spark at all...
-Robert
Old Oct 28, 2003 | 09:45 PM
dkeers's Avatar
I saw that after I posted. Sorry
Old Oct 28, 2003 | 11:17 PM
Robert95z's Avatar
no problem...
So its the optispark right? I want to know for sure before i spend the mega cash on an opti... (guess im not replacing these chitty 2.73 gears anytime soon )
Old Oct 29, 2003 | 10:33 AM
Robert95z's Avatar
So? Is this the opti?
Noenav
Mar 1, 2019 07:38 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
Chris Anderson
Jan 27, 2015 08:30 AM
ChrisFrez
Nov 30, 2014 08:41 AM
