1.7 r. rockers
Old Aug 25, 2005 | 02:57 PM
fokwolfe95's Avatar
1.7 r. rockers
If I'm not doing a head/cam swap for a while, would it be worthwhile to step up to this high a ratio rocker with the appropriate valve springs? Who makes this high ratio rocker with matching springs? Would I also need new valve covers? Thx.
Planning on doing this at the same time of a header install + tune.
Old Aug 25, 2005 | 03:29 PM
MyShibbyZ28's Avatar
Re: 1.7 r. rockers
I think the brand is scorpion that makes alluminum 1.7's. If you still have the stock cam it'll raise the lift from .447 to .506, and new springs and stuff would be a good idea at that time. and you'll most likely need tall center bolt valve covers instead of the stock ones. I've also heard of the LT4 valve covers working.
Old Aug 25, 2005 | 04:20 PM
Kurt Crosbie's Avatar
Re: 1.7 r. rockers
How come the most common type of roller rocker seems to be the 1.6? Why don't people use the 1.7 on larger cams? And how come I see people sometimes with 1.52's with a .600 lift cam?
Old Aug 25, 2005 | 05:33 PM
fokwolfe95's Avatar
Re: 1.7 r. rockers
I'm assuming less flex at higher RPMs with the lower ratio rockers. Think its better to have the lift ground into the cam. But in my case where I have the stock cam, I'm not going to sweat it till the next rebuild.
So LT4 springs are enough?
Old Aug 25, 2005 | 07:08 PM
Re: 1.7 r. rockers
The LT4 springs can handle about .520 lift or something max. so if you're going with just 1.7's and no cam, they should do the job.
Kurt Crosbie: i think most people go with 1.6's because it's not over the top, but also adds some lift. 1.7's are more for people that aren't going to do a cam swap or are racing. i don't know why people go to 1.52's from 1.5, i think it's a waste personally, you gain about .005 lift. It brings it from .447 to .452
Old Aug 25, 2005 | 08:18 PM
Re: 1.7 r. rockers
Perhaps people use 1.52 because it is a common aftermarket part. I don't think anyone would want to use stock rockers on a 12:1 setup with 250/256 cam.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
