1.6 rr's=higher rev
Old Nov 17, 2003 | 05:34 PM
speedracer93z28's Avatar
1.6 rr's=higher rev
i just installed 1.6 rr's and i was wondering if i should raise the rev limiter (have an A4), do i make more power up top? thanks
Old Nov 17, 2003 | 05:41 PM
drewstealth's Avatar
I believe it will more the power band up a bit. You do have aftermarket springs on there right?
Old Nov 17, 2003 | 05:45 PM
just the rockers
Old Nov 17, 2003 | 06:13 PM
speed_demon24's Avatar
Don't shift any higher than 5800, my power drops off like a rock above that.
Old Nov 17, 2003 | 07:10 PM
Yeah the power will start to drop off around there with the stock cam. But even if it didn't i wouldn't take it over that with 1.6rr's and the stock springs.
Old Nov 17, 2003 | 08:09 PM
dave1w41's Avatar
Without better springs, you probably won't gain any power because the stock springs are at their limit with the 1.5 rockers. You need a set of LT4 springs and then you can raise the rev limit to 6000. The car is still pretty tapped out at that RPM.
Old Nov 17, 2003 | 08:13 PM
Heatmaker's Avatar
Advanced Member
where can one purchase some cool springs?
Old Nov 17, 2003 | 08:26 PM
96LT1TX's Avatar
www.cmotorsports.com
I bought the ex components 612 springs... good to .600 lift (someone correct me if I'm wrong, but thats why I bought them) they arent too much $$ either.
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
