1.6 rr?
Old Apr 3, 2003 | 08:30 PM
1FASASZ's Avatar
1.6 rr?
I have a 95 camaro and i want to get some 1.6 nsa rr for it and i was wondering what i have to change i heard i would have to change my pushrods will i have to change my springs? and what else will i have to buy?thanks
Old Apr 4, 2003 | 04:48 AM
craigffb's Avatar
Re: 1.6 rr?
I've never heard of the rr your wanting, but when I put mine in I got all new parts, rockers, springs, caps, locks, shims, and valve seals. If your gonna do the rockers you should do it all at once. Just my .02.
Old Apr 4, 2003 | 06:48 AM
Lunarson's Avatar
I have always heard that 95's came with hardened pushrods so it probably wouldn't be necessary to change them. Springs are an issue, most suggest upgrading them while others "myself included" stick with stock springs. You have to set the rockers at a 1/4 past zero as opposed to 3/4 to get away with reusing the stock springs which even at that its close to bind and some say the stockers won't last long, mine only have 3000 miles on the clock at this point, the post I've read didn't specify how long they held up just that they didn't long. Anyway if you upgrade the springs you might as well replace the seals, caps, locks and I'm not certain how a shim comes into play on a valvespring but I've heard its necessary to use them, I can only imagine that its to establish a certain amount of seat pressure which if thats the case in a sense your taking away some of the lift capability of the spring by shiming it but appearantly it isn't a significant amount.
Old Apr 4, 2003 | 03:28 PM
1FASASZ's Avatar
Thumbs up
thanks
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
