1.6 r/r installs please help
Old Jul 16, 2003 | 11:39 PM
DTABFORMULA's Avatar
hi everbody i just bought crane cams roller rockers 1.6 s/a.. and i bought new pushrods same length, stock heads, and i was going to tighten the r/r and the bolt started to get tight, is there anything else i have to change the pushrod was still moving up and down i loosened it cause i didnt want to break anything???
i dont know if i have to change anything else.... thanks for any info u have...
Old Jul 17, 2003 | 12:06 AM
slashz28's Avatar
first, dont loosen after theyre tightened the up/down play shouldnt be there either. tighten the nut slowly till you remove any up/down movement from the pushrod. give it another 1/2 turn past that, tighten the lock, and youre set
dont make the mistake of tightening (initially) till you remove all spin from the pushrod, only the up/down movement.
if youre to loosen at all after, loosen completely and retighten again. dont tighten down and then loosen.
make sense?
and i suppose you are tightening them at TDC #1 and #6, right?
hth
Old Jul 17, 2003 | 12:07 AM
Bud M's Avatar
Make sure the piece in the middle of the rocker body has the right side up.
Nov 18, 2023 07:21 PM
alliance12364
Mar 6, 2015 04:39 PM
thenewkid
Nov 27, 2014 09:41 AM
