1.55 rr?
Old Feb 17, 2009 | 05:23 PM
  #16
stephenspann27's Avatar
When I get ready to do it, think I'll call Comp Cam's hot line.. and get a recommendation..
Originally Posted by BUBBA
Just do it right: begin with checking the cam card for your cam and see what spring pressures and heights are recommended for the cam with 1.6RRs. Should be at least a dual spring. Suggest going with non-self adjusting RRs with the guide plates and hardened pushrods----check your geometry to ensure the correct PR length. SB std length, but better to make sure.
If you bring each cyl to TDC you should be able to change out your springs without dropping the valve into the cylinder. Be sure to get the proper spring compresser for the job. For that matter, be sure to check out all recommendations on this board regarding the RRs, Springs, PRs, Guide Plates, etc.
With the additional lift and a bit more duration, along with the proper combination of parts you should get the maximum power out of your cam along with a solid, well-controlled valve train. JMHO
Old Feb 17, 2009 | 06:21 PM
  #17
n2ceptor's Avatar
Originally Posted by Stl94LT1
The LT4 springs are really not that good for any cammed LT1.
?????????? That a blank statement?????? I have no issues running LT4 springs with a Crane 227 cam w/ CC 1.52 rockers..... It all depends on the setup that is being used and all the components work together for the engine to achieve maximum potential......
Old Feb 17, 2009 | 06:33 PM
  #18
Stl94LT1's Avatar
..........and yours is probably not achieving its maximum potential with those springs.
Old Feb 17, 2009 | 07:58 PM
  #19
n2ceptor's Avatar
I am happy with my set up.....
Old Feb 17, 2009 | 10:45 PM
  #20
deerslayinrenek's Avatar
It's really not that big of a deal to change springs while it's still on the car.....I had nightmares about doing it, bring each piston to top dead center and it works out great....dont sweat it and good luck either way
meengreen 94z
Apr 19, 2017 01:22 AM
Trevor98ramair
Jun 9, 2005 10:16 PM
Camaro90RS
Jan 6, 2005 04:03 AM
steelheart
Aug 25, 2003 09:57 AM
Punisha69
May 25, 2003 12:18 PM
