1.5 or 1.6 rr with xe 230/236 cam?
Old May 9, 2003 | 07:52 AM
Timberwolf's Avatar
Which would you choose? I'm using the crane 10308 springs...
Old May 9, 2003 | 08:50 AM
Gripenfelter's Avatar
I'm using Comp 987 springs with a 1.6 rocker on the XE 230/236 cam.
You'll love it.
Old May 9, 2003 | 10:04 AM
atljar's Avatar
More lift is always good. 1.6
Old May 9, 2003 | 10:48 AM
97Z-M6's Avatar
i would go to www.cmotorsports.com and get a cam with a taller lift instead of 1.6rr it would probably be cheaper to
Old May 9, 2003 | 10:53 AM
Timberwolf's Avatar
Really? you think there's much difference in price from 1.6 RR to 1.5 RR? I'm going rollers either way, it's just a matter of picking out a ratio.
Old May 9, 2003 | 01:01 PM
97Z-M6's Avatar
you can pick up a set of new?used 1.5rr on thr board all the time. and it would be easier on your valve trane with the lift coming from the cam.
Old May 9, 2003 | 01:15 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
get 1.5, give me 8. I'll give you 8 1.6's.
Old May 9, 2003 | 01:35 PM
chevyguy3's Avatar
1.5s will provide better valvetrain geometry (not that it will really make much difference with your combo). IMO, i would have Cam Motion make you a custom grind with all the lift you need, and do 1.5s
Old May 9, 2003 | 01:45 PM
97Z-M6's Avatar
just looked on the 4sales section and a set of comp 1.5rrs sold for 60 buck.
agian i would have a custom grind done. call cmotorsports and talk to seth. he seems to be a straight shooter.
Old May 9, 2003 | 02:40 PM
llafro's Avatar
If you already have the rockers, that's one thing. If you have to buy them, then there is no price difference from 1.5 to 1.6. I bought new ones and the price listed for the Comp Pro Magnums was the same whether you wanted 1.5 or 1.6 and 3/8 or 7/16 studs. Since I had to get new studs and guideplates anyway, I went with the 7/16 size and 1.6.
BRAD
Old May 9, 2003 | 02:41 PM
Timberwolf's Avatar
BRAD
Yeah, that was my point too... just wondered if I would have any problems with coil bind or piston to valve clearance, issues with drivability, etc. I don't have the rockers yet...they're next on the list
Old May 9, 2003 | 03:21 PM
Other cams don't have as aggressive ramps as the XE series. Thats one of their key features.
Also you would need all 16 rockers to be 1.6 not half and half like a cc305.
Old May 10, 2003 | 11:03 PM
arnie's Avatar
How do you figure that? The pivot point has not changed. Lift at the valve, is lift at the valve, regardless of what generated the valve movement. You have one choice (short of changing the pivot point) to improve upon a lousy situation, that being adjusting the pushrod length.
Personally, if I wanted a certain amount of lift at the valve, I consider a higher ratio rocker easier on the cam.
Why would a person need 16 rockers of the same ratio?
oldschool
Feb 9, 2016 09:21 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
Killer94z
Jan 13, 2015 12:06 PM
slocody
Feb 10, 2003 01:04 PM
