1.45" Diamater sprgins.. which ones are the best and which valves?
Old Apr 19, 2003 | 04:15 PM
Highlander's Avatar
I am in need to change my 6yr old springs in favor to something that can give me more reliability at higher RPMs. What do you guys recommend?? I want to rev till 6400.. the AFR just dont cut it anymore, I feel... I have an Aluminum flywheel which is lighter than stocker so it can rev!!
While at it.. any thoughts on good valves? Pros and COns???
I would like a rev happier setup as I will be installing a 4.11 soon..
I have an XE 224/236 cam in and AFR 190s
I have installed chrome moly retainers and standard stainless steel valves.. so I could use the improvement..
I am forced induction and I plan un upping the boost too so springs are a concern.. Thinking over a Hydra rev kit...
Let me know your oppinions... Thanks
Old Apr 21, 2003 | 09:14 AM
kmook's Avatar
Advanced Tech Moderator
You may get more responses in LT1 Tech, moving.
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
