1/4 time estimate
1/4 time estimate
I'm not sure where to post this thread?
I was wondering if anybody could give me a guesstimate on what kind of 1/4 mile times my car would run and Hp Range I'd be in? All the 1/4 calculators estimates use HP and I don't know mine. Here My Mods :
95 Z28 Conv w/
Hurst 6 speed short throw shifter w/ Centerforce dual friction Clutch
4.10 gears and aluminum driveshaft
6lb powerdyne charger
port matched stock heads and intake
Slp long tube headers w/ Loud mouth exhaust
MSD 6 A Ignition
30 lb injectors with 2 fuel pumps and regulator
95 Z28 Conv w/
MSD 6 A Ignition
I agree - bench racing sucks.
Weigh it and run it - then revisit the calculators. Your numbers will equate to a close hp rating.
Until you get timeslips - it's a total guess.
Good luck - sounds promising!
High 12's low 13's. could be higher or lower with so many variables. I hope you have a tune with all those mods. Definately with the injectors you should have one. How do you like that Powerdyne?
Assuiming the tune isnt grabage and he can drive this thing should easily be out of the 13's.
This car should run 11's.
I agree he should run 11's if its dialed in with slicks. I assume he has street tires and would have a high 60' time. So many things could affect his horsepower like others said earlier its real hard to say. It seems the more mods everyone does the more issues there are to deal with.
