1/4 mile time predictions
Old Jan 23, 2006 | 05:28 PM
dsmawd350's Avatar
looking for some info on what you guys can knowledgely predict my car to run since its in the shop right now goin under the knife.
its a 93 z28 M6 mods include:
3.73 gears
SLP differential
Lakewood LCA's
aluminum DS
LT-4 clutch
moroso CAI
performance wires and coil
NGK TR6's
Pacesetter LT's
3" off road y
open cutout at end of y
CC306 cam
comp pro mag 1.6 RR's
kmotion k800 springs
titanium retainers
hardened pushrods, guideplates, comp lifters, etc.
mezier electric WP
NX 125 wet shot
and a good tune
with some ET streets and say around a 1.6 60ft what would you guys expect a setup like this to run
and what kinda hp numbers on and off the juice
Old Jan 23, 2006 | 06:26 PM
69z-28's Avatar
Re: 1/4 mile time predictions
thats some combination youve got. i dont have any real experience with mods like those but from what ive read i think a low 11 is possible with the spray and prolly a high 11 or so N/A if you can get it to hook. good luck let us know how it goes.
Old Jan 23, 2006 | 06:34 PM
Titus's Avatar
do you have a 12 bolt? if not when you leave on those ET streets that 10 bolt will go bye bye. If you have a 12 bolt then i think mid 11's are possible, if on a 10 bolt low 12's are more than likely
Old Jan 23, 2006 | 06:39 PM
dsmawd350's Avatar
no im on the 10 bolt ive read quite a few people pull off 1.5 60ft times on the 10 bolt and et streets i know im on borrowed time but im hoping itll stand a few good launches http://web.camaross.com/forums/showt...hlight=nitrous
Old Jan 23, 2006 | 07:45 PM
69z-28's Avatar
i was gonna ask that. just slip the clutch a little you should still pull like hell with that cam and nitrous.
Old Jan 23, 2006 | 08:31 PM
chevy94c's Avatar
I think 11.6.
Old Jan 23, 2006 | 10:25 PM
speed_demon24's Avatar
I'de say a 12.0 and the clutch will be shot after the 1st run...
Old Jan 24, 2006 | 12:30 AM
Bersaglieri's Avatar
W/ CC306 - 344rwhp/347rwtq
W/ 125 shot - 446rwhp/489rwtq
12.4 @ 112 w/ CC306
11.5 @ 120 w/ 125 shot
This is before you have driveline and stock bottom end problems. I can only imagine revving the CC306 to its potential at 6500rpm - 6700rpm and add 125 shot/shock to that
Is that the 93 T56 with the deep first gear?
-Dustin-
Old Jan 24, 2006 | 11:19 AM
dsmawd350's Avatar
12.4 @ 112 w/ CC306
-Dustin-
im hoping for 350/350 with the cc306 and atleast 450/480 with n20
yes it is the m29 T56 ive been told a 3.73 with my M29 is like a 4.10 on 94-97 cars
Old Jan 24, 2006 | 01:31 PM
You also have to remember its not as strong.
-Dustin-
Old Jan 24, 2006 | 01:55 PM
streetrod93's Avatar
the m29 in first gear with 3.73 gears is the same as a 4.16 gear in 1st of the 94+ m6. and yes, they are a little weaker... i know, mine took a crap the day after we tuned the new motor....
as for the rear end, everyone is different....i've seen them take 1.48 launches over and over, and then again, i've seen them **** parts on the track from 1.98's....it's really just a crap shoot
my prediction is LOW 11's on spray, and right around 12.00 on motor.
Old Jan 25, 2006 | 02:28 PM
'94 Bad A Z28's Avatar
My car with 3.73's/2800 converter and a NX Wet 100 shot went 12.1 @ 116 on a crappy 1.87 60'. So I would beffinately be hoping for somewhere in the low 11's.
Old Jan 25, 2006 | 02:29 PM
I'm sorry, that was with the stock 3.23's.
Old Jan 25, 2006 | 02:32 PM
Javier97Z28's Avatar
Moderator
That 10 bolt will be trashed in no time with a spray launch in a 6spd.. sorry.
I'd still count on 11 second passes even w/o launching too hard.
Old Jan 25, 2006 | 11:48 PM
Some 10 bolts are freaks. My friend has a cc306 on a big shot, and launches the hell out of it on the street all the time with m/t dr's, and it still hasn't broken yet. I mean multiple times per week and heating up the tires. One of my other friends on the otherhand is on his 13th set of gears, no joke. So I guess its the luck of the draw and how the gears are setup...
