1/4 ET Guess
Old May 12, 2005 | 02:34 PM
LT1 POWR's Avatar
1/4 ET Guess
This dumbass kid who thinks he knows everything about everything at my school doesnt think i will get below 15's in the 1/4. With my mods what do you guys think i will be running.
Old May 12, 2005 | 02:46 PM
80TA's Avatar
Re: 1/4 ET Guess
There are a lot of variables like what altitude your track is at .And what tires are you running on ..If stock then what gears.. Does your car have 2.73 gears or 3.23? Quick way to tell is do you have a 1 or not on your console plate. No 1 then 2.73s. At least pretty sure thats true. with 2.73 gears would think should still see some mid to maybe low 14s and with 3.23 maybe a low 14 high 13 but if you are at high altitude it could make these times much worse.
My vert ran 15.0 at local track at 1900 feet but mostly stock.With magnaflow and 3.42 gears got it down to 14.3 and vert is about three hundred pounds heavier than your car likely depending on driver. Buddies car with minor mods,no headers 94 z runs low 14s with 13.8 best with a 2.0 60ft on drag tires.Our track sucks for traction usually . I think you should be the guy money that you will be under 15s. You should win unless you are like in denver or something.
Old May 12, 2005 | 02:57 PM
trans9_5am's Avatar
Re: 1/4 ET Guess
I ran 13.87 with whats in my sig with 2.73's. I am pretty close to sea level though.
Brandon
Old May 12, 2005 | 05:38 PM
txbitt's Avatar
Re: 1/4 ET Guess
The dumbass kid at your school must be a ricer who thinks 15 is fast because that is what they are used to running for the most part. My 94 ran 13.99 bone stock with factory 3:23 gear. You should be mid 13 on a nice cool evening easy.
Old May 12, 2005 | 05:44 PM
LT1 POWR's Avatar
Re: 1/4 ET Guess
Yea im in nebraska and i have 3.23 stock gears.
Old May 12, 2005 | 06:02 PM
Nick-LT1's Avatar
Re: 1/4 ET Guess
I am close to see level and i have the same intake you do but i only have mac mids and i ran a 13.5 at 102 mph. so you could run a 13.3 or 13.4 if your car is in good running order.
9t4lt4z28
Oct 2, 2015 10:28 AM
HAWG
Sep 25, 2015 11:41 AM
Greg88
Sep 20, 2015 07:14 PM
leftclixLS3
Sep 17, 2015 03:12 PM
