02 sensors or not?
Old Apr 28, 2004 | 06:11 AM
customlt1's Avatar
02 sensors or not?
have 1997 TA w/ 50k..hooker LT and y pipe install in the next 2 weeks also doing plug and wires..is getting the 02 sensors extensions worth it now ive heard yes or no..BTW car never raced and no serious mods..bolt-ons thanks
Old Apr 28, 2004 | 08:31 AM
customlt1's Avatar
Any help would be very appreciated..
Old Apr 28, 2004 | 08:35 AM
EviLBoX's Avatar
You will need O2 extensions when you have your Hooker long tubes installed, I would go ahead and get them. When I first had long tubes I just extended the O2 sensor wire and it worked fine, but when it came to new O2 sensors it came down to either splicing the new O2 sensor wire or just buying an extension, I bought an extension.
Old Apr 28, 2004 | 08:39 AM
customlt1's Avatar
so 02 sensors AND extensions or just extensions..also what length should i go with..? thanks
Old Apr 28, 2004 | 08:50 AM
AStockerifficZ's Avatar
From: Born in Chicago IL, Grew up in Aurora IL, Stationed in Jacksonville FL.
extensions
You have to have the O2 extension wires if you dont feel like splicing into the actual wires themselves. The factory wires wont reach the O2 bungs in the collectors of the longtubes. So although splicing wires isn't hard, if you dont feel like doing it, buy the extensions, i paid 26 bucks for a pair.
Old Apr 28, 2004 | 01:43 PM
customlt1's Avatar
icic..new 02 sensors or not on a 50 k 97 TA?
Old Apr 28, 2004 | 01:48 PM
WS Sick's Avatar
If you have never replaced them on this car, now would be a fine time to, Depending on where your O2 bungs are will determine the length of extention you need. If you have in header collector Bungs you only need 1 foot of extention, if they are in the y-pipe then you'll need a little longer.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
