02 connections on a 97
Old Sep 19, 2005 | 11:13 AM
Pampered-Z's Avatar
Just want to double check myself after installing MAC headers:
On a 97 are the connections for the 02's the same front/back? That is, are the front 02's both flat connectors and the after cat 02's the square connectors?
Looking from under the car the D.S. 02 after the cat goes into the connector in front of the starter against the block. And the pass. side before the cat goes into the flat connector that is against the wheel well. Correct?
Old Sep 19, 2005 | 11:15 AM
96m6lt1's Avatar
Re: 02 connections on a 97
you are correct the front o2's are flat plugs and the rears are square :thumbsup:
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
Bxlt1
Sep 10, 2015 08:16 AM
