~How much $ to clearance block for 383? Max overbore on these LT1's?
Old Apr 15, 2003 | 12:56 PM
Dave88LX's Avatar
I'm HOPING I can clean up my cyl wall with a .030 overbore, but I won't know until I bring it to the Machine Shop. I've read that one needs to clearance the block for the stroke of a 383. Anyone know how much ~$ this costs?
My other question, is how much of an overbore can these blocks take roughly before a sonic check is required?
Thanks!
Old Apr 15, 2003 | 01:29 PM
rickb@lynk.com
Guest
Posts: n/a
Hi Dave,
I don't have receipts in front of me but I think that the additional clearancing was minor. Some additional clearance was needed at the very front for the crankshaft and a little at the point on both sides where my H-Beam rods were wider then stock. They only spent about thirty minutes grinding. I had an issue with the stock oil pan as well but I don't know if this was caused by the crankshaft or the connecting rods. I ended up spending about 350.00 for a very slick Milodon setup. I hear the Canton is about the same.
Old Apr 15, 2003 | 01:39 PM
Dave88LX's Avatar
Thanks for the info Rick. I just got off the phone with the builder.
$65 to put a sleeve in the cylinder if he can't clean it at .040, and $125 to clearance the block. He said they don't weld cranks anymore, so if it's beyond it's use, then we're going to have to go with a new one.
GRRRR
Old Apr 15, 2003 | 03:31 PM
Mindgame's Avatar
Re: ~How much $ to clearance block for 383? Max overbore on these LT1's?
Thanks!
.040 is as far as I'd go. If you just had to go .050 or .060, then you'd be wise to sonic check. I wouldn't be too keen on going that far on these blocks though.
-Mindgame
F'n1996Z28SS
Aug 23, 2023 11:19 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
