~15 CFM worth $500?
Old May 21, 2004 | 05:36 PM
Valkyn71's Avatar
~15 CFM worth $500?
Planning on having my heads done in the near future.
One port jobs keeps the stock vavles, and flows aprox 255/180.
The next level uses larger Ferrea 2.00/1.56 valves and flows ~270/190.
So im curious if you all think that ~15cfm is worth the extra $500? What kinda performance gains do you think i would see from the better heads?
Also would the 270/190cfm heads support a 383? in the distant future i might be doing one.
Old May 21, 2004 | 06:20 PM
95_LT1_6SPD's Avatar
I would go for the stock sized valves with 224/230. But if your planning to step it up to a 383, i would want all the flow you can get.
Old May 21, 2004 | 07:10 PM
jkipp84's Avatar
I could be wrong, but I don't think taking the two peak flow numbers and comparing them is looking at the whole picture. The stock valve size may be fine for your particular application, I don't know, that's a different story. But I think there's more to it than just those 2 numbers.
Old May 21, 2004 | 07:26 PM
scoobysnax83's Avatar
not really. Flow number are everything in heads. What matters is the cam. Heads that flow better won't flow better if not utilized by the cam. The only differences would be the actual porting technique. Since he is talking about the same company, that is out of the question.
Old May 21, 2004 | 07:28 PM
Valkyn71's Avatar
Do you guys think the 2nd set would support a 383?
I dont wanna spend the extra money now, then find out i will need AFRs later.
Old May 21, 2004 | 07:30 PM
Dave88LX's Avatar
2nd set will support a 383. Do it all out now, spend the extra. Don't put the engine back togother, drive it, and say "I wish I spent the extra $500 when it was apart".
Old May 21, 2004 | 09:21 PM
besz28's Avatar
spend the extra 500
Old May 21, 2004 | 11:07 PM
o yea, spend the extra $500... I meant to say that
Old May 22, 2004 | 01:44 AM
LilJayV10's Avatar
I think what he was trying to say is, peak numbers aren't the whole story, under the curve and average numbers are important, it's like a dyno graph, yeah peak numbers are good, but I would rather have a graph that looks like a table and not a moutain, if that makes any sense to anyone.
Jason
Old May 22, 2004 | 02:01 AM
disco192's Avatar
Well if your flow sheets look like mountains and your cam look like a table it can be ok too Solid roller cams with HUGE duration can make use of high peak #s.
Old May 22, 2004 | 08:28 PM
Dave Feerst's Avatar
ditto
it all boils down to what cam you are using, With a small cam the first set of heads would probibly be better because 250 CFMs will fill the cyl till 6000 or so. With a bigger cam which would go to 6500 or more, or if you stroke it, you would want the extra 15 CFMs to fill the cyl, at those higher RPMS.
Old May 22, 2004 | 08:46 PM
Valkyn71's Avatar
When i do the head swap im also going to put in a custom cam which is a little larger then the 224/230 and should be making around 400 RWHP.
I think ill spring for the extra $500, since its the "under the curve" area that im disapointed in with my 224/230. The custom cam is supposed to have much better under the curve power.
Its a similar design to the guy who just ran the 11.7 N/A
Old May 22, 2004 | 10:55 PM
1 Nasty Bird's Avatar
Dont forget about the combustion chambers and ports, flow #s arent everything, velocity is pretty important too. Theres alot more to it then peak flow #s!!!
Old May 22, 2004 | 11:50 PM
kmook's Avatar
Advanced Tech Moderator
Good point runner size. I could have some nice 380cfm sb2.2 heads right now but i dont think a 300cc runner would act nice.
Peak #s are of little importance at least to me. I spent $3k on my current set of heads which only flow 28X cfm at .600, I could have had a set of AFRs that flow 300cfm, but my low/mid lift #s kick huge ***, and since you hit every lift point twice in one valve opening except your peak which is only hit once, i'll take the low/mid lift.
As far as 15cfm for $500, I'd do it.
Old May 23, 2004 | 12:50 AM
SStrokerAce's Avatar
Yep
