$0.85 Optispark screw removal tool.
Old Sep 30, 2006 | 10:22 AM
wrd1972's Avatar
Here is my super custom made optispark removal tool for the cost of bubble gum. The whole thing cost 85 cents from Ace hardware. Sure beats $25.00+ for socket sets you will never use on anything else.
Torx head screw $0.50
Wing nut $0.25
Jam nut $0.10
Opti cap removed in 60 seconds. Priceless
I just jammed the nut and the wing nut together with some locktite and ground the torx head down a tad to fit in the recessed areas of the cap.
The thing worked perfectly to remove those retarded inverse torx headed 3.5mm screws. Plus you dont have to damage the threads on you TB cover screws.
Old Sep 30, 2006 | 10:46 AM
pearlpurple's Avatar
Re: $0.85 Optispark screw removal tool.
Appreciate you sharing that with us, good thinking when I do mine I will be making this little gem.
Old Sep 30, 2006 | 11:47 AM
01Z's Avatar
01Z
As always, your helpful posts are keepers. I followed your instructions on fixing the window motor instead of throwing it in the trash. Wondering what you do for a living now.
Old Sep 30, 2006 | 04:38 PM
wrd1972's Avatar
I am a development engineer for a major printer/copier manufacturer. Part of my job is to solve sticky problems. I even amazed myself with this creation.
Old Sep 30, 2006 | 07:13 PM
HardcoreRM125's Avatar
Hahah O wow where were you 4 years ago when I started the reconstruction of my car. I bought it totled when I was 16, and rebuilt it. But all the accessories were already off since the engine/tranny was pulled to do frame work.
I replaced the cap and rotor on mine while it was out. Figured id be dumb not to. This was when I was 16, and didnt realize I should have just replaced the whole thing.
This could have saved some time and money. And, like you said, tools I likely, will, only use one or two times again.
Old Sep 30, 2006 | 10:40 PM
socalchris2002's Avatar
Good advice, here's an even cheaper way, I removed the torx screw from the air intake cover and put a couple of nuts on the threads the same way you did and tightened them against each other... Then used it as a socket to take the opti apart. I looked everywhere to try to find that dumb E2 sized female socket, I think thats the size that no one has, so the final cost was like .10 or less for the dopy nuts
Old Sep 30, 2006 | 10:54 PM
E4...
Old Sep 30, 2006 | 11:55 PM
Severous01's Avatar
you should be an engineer.......this kind of thinking is amazing. you'll be the next ebay power seller or the next casino owner with this thinking
Rod Bender
Nov 7, 2023 02:30 PM
timmy39120
May 2, 2015 05:12 PM
ad356
Apr 11, 2015 11:12 PM
pologreen97z
Dec 2, 2014 10:42 AM
squarehead
Nov 21, 2014 08:02 PM
