Z06 Maf
Re: Z06 Maf
i believe it has to be recalibrated as well as run a special connector to mate 2 different types of plugs together.
i had one on my LT1...seemed to help in top end...but it wasn't anything spectacular. if nothing else it's a cheaper replacement for teh factory if you ruin your stocker
Re: Z06 Maf
Not trying to jack, just a thought....
I noticed that the SLP 80 or 85 mm MAF sensor looks almost identical to the ZO6... Am I halusinating?? or did SLP just re-cal it and stick their name on it?
Re: Z06 Maf
there are only so many ways to make the same unit. so it's probably similar...hard to say.
but i know the zo6 doens't come with the screen.
here is the stock maf next to my old zo6 maf (has since gone bad)...nice difference
Re: Z06 Maf
TSP use to make a lid that had an opening to fit the 85mm maf sensors.
but the maf i got came with a piece of hose to mate the two up...like the stuff they use on turbo piping
here is the pic
here is the pic
Re: Z06 Maf
Re: Z06 Maf
Originally Posted by Vicious95Z28
Do I just need to get a connector for the z06 MAF and tie my IAT wires into it? How did you do it? If I get a MadZ tune will that take care of the calibration? How do you calibrate a MAF? Sorry for all the ?'s
Calibration is done electronically by the manufacturer.
tommalcolm
Sep 11, 2015 03:39 PM
