WS6 lower air box same as the stealth box?
Old May 25, 2003 | 07:23 AM
96Z28man's Avatar
Are the two the same, and if so how much would it cost to buy a lower WS6 air box from GM? $299 seems like alot for the stealth box
Old May 25, 2003 | 09:47 AM
SS1LE02's Avatar
No, they are different. The Stealth lower air box is a lot bigger.
Old May 25, 2003 | 11:00 AM
SunsetWS6's Avatar
Wink
The Stealth is larger than a WS6 lower airbox & it doesn't have a bottom. The one problem with the Stealth set up is that the connection from the lid to the MAF is oval & small, not round & large like the other lids. It's confusing because it's well made but that seems to be the restriction on it. I had one for about 6 months. I switched to the 85mm carbon fiber TSP lid which I'm very happy with. A new WS6 lower airbox can be bought for $78 shipped from Gene at Fred Beans on LS1.com.
Old May 25, 2003 | 11:25 AM
ZIPPERR's Avatar
Someone did a dyno tests a while back and found no gain in hp between aftermaket and the stealth..
Sunsetws6, Thanks for emailing that info the other day..
Old May 25, 2003 | 01:32 PM
96Z28man's Avatar
is there any gain from going to a Ws6 box over the stock one?
Old May 25, 2003 | 05:37 PM
SunsetWS6's Avatar
ZIPPERR no problem.
96Z28man no.
Old May 25, 2003 | 05:54 PM
psychocabbage's Avatar
I did the testing.. I dont think that you will see any gains at the dyno or track by opening up the underside. Fact is that air isnt having a hard time getting to the engine once you put on a lid. Its ability to breathe seems to of been made easier with just that addition.
It would be kewl if people that worked at a dyno shop and could dyno whenever would do simple things like dyno then add a part then dyno again.. then drive for a while.. do some errands.. then dyno again.. see what happens..
I am just weird like that and want to know..
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
LS1346CID
Aug 27, 2002 12:27 PM
Eric @ DMS
Jul 30, 2002 07:47 PM
WJH'sFormula
Jul 28, 2002 04:51 PM
