Wow! Looky at what broke! (PIC)
Old Aug 26, 2003 | 09:46 PM
Ferocity02's Avatar
Red face Wow! Looky at what broke! (PIC)
I was driving home the other day, driving like a normally do and hear the banging coming from the rear. I have no idea what it was, but it was extremely loud. I looked after I got home but didn't see anything, took another look today and found the problem. The bolt that the sway bat mounts to broke in two! Can anyone suggest how to fix it, more than just take out the old one and out in a new one. Like where to jack the car and what not. And where do I get another one and what are they called? Thanks!
HERE is the pic
Old Aug 26, 2003 | 09:49 PM
6speedZ28's Avatar
its called an "end link". When I lowered my car my bolts broke cause they were rusty when I tried to lossen them so I upgraded to polyurethane endlinks. The bolt is thicker and I am told it will resist rust....and the bushings aren't rubber.
Old Aug 26, 2003 | 09:55 PM
Ferocity02's Avatar
Where do I get one?
Old Aug 26, 2003 | 10:00 PM
6speedZ28's Avatar
as sorry as I am to say this....I was in a bind and had to get mine at Pep Boys
Old Aug 27, 2003 | 02:22 AM
2xLS1's Avatar
The GM part # for just the bolt is 10018984. Dealer list is $3.80. If you have a good bolt hardware store around you, the size is M8x1.25x180MM. Just make sure you get at least a grade 8.8
Old Aug 27, 2003 | 06:18 AM
Waroo's Avatar
Man, that sucks! I plan on lowering my car soon, I'll definitely keep an eye on that.
Old Aug 27, 2003 | 07:21 AM
My84Z's Avatar
just get one from pep boys or autozone there is not much difference in them or any others .
Old Aug 27, 2003 | 02:03 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Smile
Replace both sides with new bolts and poly bushings.
http://www.rksport.com/prod_detail.p...66&view=detail
http://www.lmperformance.com/1569/1.html
The pictures above are for the front endlinks, however both of these sights carry the rear endlinks as well.
SteveC
Old Aug 27, 2003 | 03:25 PM
LurkerLS1's Avatar
Crikey! And you say you were "driving like you normally do"? You weren't doing anything ill advised at the time it broke? Weird.
Old Aug 27, 2003 | 04:31 PM
CODY BEHNKE's Avatar
Just a note, all 1993 and newer cars have poly end links already!
The one on your car doesn't look stock, factory bushings are white looking.
Old Aug 27, 2003 | 04:47 PM
2002Z28SSConv's Avatar
I was thinking the same thing too. I realize that they are dirty so the color may not be truely representative of what you have. But the shape of the endlink itself is why I was thinking it might not be a factory part you have on there. With that in mind it could have very well been tightened incorrectly by the previous owner and weakened.
Old Aug 27, 2003 | 06:32 PM
SteveC's Avatar
I respectfully disagree, my car is a 2001, and upon removal and inspection of my twisted up end link bushings (after 5000 conservative miles of driving), they were so soft and plyable (sp) there is no way they could have been poly bushings.
JMHO
SteveC
Old Aug 27, 2003 | 09:28 PM
Ferocity02's Avatar
Fixed it!!! I bought a kit from Autozone made by Energy Suspension. The kit took some modification to make it fit like the other side. I grinded about 1/4" off of the metal sleeve, put 5 washers below the head of the bolt to raise it up, and reused one of the stock bushings. The other three were absolutly shot. After driving it felt a little more solid, I think some of the noises went away. Can't wait until I get the other side in, but I'll save that for when I do the axles.
Old Aug 27, 2003 | 10:51 PM
rncotton's Avatar
Glad you got it fixed.
Fastbird93
Apr 9, 2016 07:01 PM
cmsmith
Jul 5, 2015 10:35 PM
NewsBot
May 24, 2015 10:50 AM
cmsmith
Apr 30, 2015 05:18 AM
sscott
Jan 17, 2015 04:30 PM
