Windshield wipers
Old Dec 26, 2003 | 10:27 AM
T.V.'s Avatar
Windshield wipers
My drivers side windshield wiper hits the window molding and has scratched it. I tried to remove the arm by removing the bolt and move it down, but I couldn't budge it. It is annoying every time I turn it on, both the sound and the fact that it's f-ing up my molding. It is the proper size. Any suggestions?
Old Dec 26, 2003 | 07:39 PM
wrencher's Avatar
You need to get arm loose from post & readjust the arm.
most of the time I loosen nut up & keep it on the top of the post's stud.
Then take a hammer & tap the nut/stub & it usually jars the arm loose.
If it is still wont budge, use a bent needle nose plier (45 degree) with some rags to cover the jaws & a flat piece of wooben shim stock.
Use the wood as a point to pry against, w/the covered plier jaws, & break it loose.
AviatorDave
Dec 19, 2016 06:35 PM
autoxr166
Sep 25, 2015 04:21 PM
Henson071
Sep 18, 2015 04:01 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Aug 5, 2015 08:35 AM
