Will a ported TB lean out my a/f mixture?
Old Aug 23, 2003 | 01:33 AM
Geeterman's Avatar
Well, as the title says, I was just wondering if a ported tb would lean out my car. I'm guessing no, since all the extra air flowing into the engine would also go through the maf sensor which would adjust the a/f accordingly. Am I right?
Old Aug 23, 2003 | 11:54 AM
Geeterman's Avatar
TTT
Old Aug 26, 2003 | 08:58 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
its fine. its air that already went trhough (and was calculated for) by the MAF.
prob a waste of $ though if its anything like it is on an LT1
Old Aug 27, 2003 | 01:55 AM
AL SS590 M6's Avatar
Moderator
Re: Will a ported TB lean out my a/f mixture?
Porting a MAF lets more air in than the sensor tells the computer. The same flow speed of air over the sensor equals more volume of air. Now the unreported air will lean the car but the computer will adjust the fuel to keep the car in the safe zone as far as air fuel ratio goes.
In my opinion screwing with the MAF at all is totally unnecessary. Look at my sig to see what you can run with a stock MAF.
Old Aug 27, 2003 | 08:05 AM
TreySpeed's Avatar
On permanent vacation
Re: Re: Will a ported TB lean out my a/f mixture?
He is porting the TB, not MAF.
Old Aug 27, 2003 | 08:35 AM
OldSStroker's Avatar
Re: Re: Re: Will a ported TB lean out my a/f mixture?
Originally posted by Ashkan Mehryari
Alter ego?
Old Aug 27, 2003 | 08:48 AM
TreySpeed's Avatar
Re: Re: Re: Re: Will a ported TB lean out my a/f mixture?
Originally posted by OldSStroker
Alter ego?
You noticed,
I'm flattered!
Old Aug 27, 2003 | 11:33 PM
Moderator
Oops misread that one.
Old Aug 28, 2003 | 10:54 AM
ratio411's Avatar
Short answer: No. It won't hurt a thing.
Long answer: It won't hurt a thing, it is a worthwhile mod on LS1 cars, but it must be done right. There are a few porting services out there that do a great job for reasonable money. Make sure they are one that fills and reshapes all the ports inside the bell.
Good luck
Dave
G-BODYT56
Jan 14, 2022 11:14 PM
PopoFormula
Oct 12, 2015 04:19 PM
drt
Sep 27, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
