Will 1999 Z28 Camaro Gauge cluster work on a 1998 Z28 Camaro?
Old Jan 12, 2004 | 02:31 PM
CaMaRoV6's Avatar
Will 1999 Z28 Camaro Gauge cluster work on a 1998 Z28 Camaro? I know 1998 V8's differ from the 1999's and up but I dont know if the same goes with the gauge cluster. Are there also some differences between the interior wiring of the 98's and the 99's? Thanks!
Old Jan 12, 2004 | 03:58 PM
SFB767's Avatar
It should work, they're both the same if they're not the one with that goes up to 110 I think.
Old Jan 12, 2004 | 04:47 PM
Eric L's Avatar
Re: Will 1999 Z28 Camaro Gauge cluster work on a 1998 Z28 Camaro?
i know the tach wire is different, other than that
Old Jan 12, 2004 | 10:21 PM
z28chrizz's Avatar
Temp gauge in the 98's reads the actual motor temp.. the 99-02 cars are programmed to sit at 210... more like an idiot light than a gauge... this should be a source of problem if any of the electronics controlling the gauges are in the gauge pod themselves.
Gm ditched the actual temp b/c the alum motors heat/cool faster and people were bringin in their cars complaining about abnormal temp fluctuations... or so the rumor goes..
Old Jan 12, 2004 | 11:35 PM
CaMaRoV6's Avatar
Thanks for all the info! I guess I'll stick with the 98 gauge cluster.
Old Jan 14, 2004 | 10:02 AM
BradleyPeart's Avatar
I can't believe it. That pisses me off!
Old Jan 14, 2004 | 07:47 PM
99SS1022's Avatar
Some of the lights are different on the 98 cluster then the 99. I am sure the cluster should work, but not sure about those lights...
hotrodyou1
Dec 20, 2014 10:05 PM
Joes96z
Dec 13, 2014 07:48 PM
ChrisFrez
Dec 7, 2014 06:01 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
