why would it be doing this????
I have a 99 camaro z28... the car has been doing this stuff where i'll turn it on and start driving , but then it'll basically start dying on me like the air flow is messed up.. i'll rev the engine and its just bogging down and seems like its chocking... it is just running like SH**.. i dont know if it could be an electrical problem, a fuel problem, or air flow problem.... It was raining really bad today and i do have an SSRA, so i dont want to say i sucked up water, but its possible could that be causing my problem.... the car seems to be lagging if that makes sense.... any input would be greatly appreciated....Thanks
first check for codes. I would change the fuel filter and check fuel pressure. read this http://www.ehow.com/facts_5183619_ba...-symptoms.html
With an SSRA in heavy rain I'd be checking to see if the filter is wet. It's pretty easy to scoop up water from a deep puddle and possibly ruin your motor. That's why they come with a block off plate to install just incase.
i found out that my car is throwing a code...P0300... it is saying that i have a random cylinder misfire... what could have cause this?... and what can i do to fix it? ive heard that it could be the coils, or even the camshaft position sensor, or crankshaft position sensor.. thanks for the help
